Ski Pole Tripod
837
4
Published
Introduction: Ski Pole Tripod
About: I hate being bored, but because of this thing called ADHD it happens more than I'd like it to. So to curb the ADHDness I design and build things and there's always music playing when I'm working on a project...
So some time during the winter my camera tripod broke. At the time I didn't really care that much, but on short notice I needed a tripod so I scavenged around my house and I stumbled upon my aunt's old ski poles. Immediately I had the whole thing planned out in my head and got to work. So here's how to make a camera tripod out of a pair of ski poles.
Step 1: Prep
So here's what you're going to need for the project
Materials:
  • Pair of ski poles
  • 6 Screw and Bolts (Round Head Combo #10 - 24 x 1 in)
  • Piece of wood at least 6" x 6"
Tools:
  • Circular Saw (or any type of saw, I just used a circular saw)
  • Jig Saw
  • Hammer
  • Drill
  • 1 in drill bit
  • 7/32 in drill bit
  • Compass (the drawing kind)
Step 2: Cutting the Legs
To start off you're going to need to cut one of the poles.
  • Remove the handles from the top of the pole
  • Measure 3 10 inch pieces
  • Cut them and discard the extra end, you will not need this
Step 3: Drilling the Mounting Holes
Now it's time to drill the holes, you will need a 7/32 drill bit for this.
  • First measure a 1/4 inch in from the top, this will be were the first hole goes
  • Then from the end of the first hole measure 1 inch, this is where the second hole will be
    • make sure the top of the hole is at the 1 inch mark
  • Repeat for the other two legs
Step 4: Making the Base
Now it's time to make the base where all the legs will attach to.
  • With a compass draw a circle with a radius of 2 3/4 in, this should give you a diameter of 5 1/2 in
  • Then with a Jig saw cut out the circle
  • Measure and mark the middle and an equilateral triangle on the base
    • I used a somewhat complicated series of measurements for the triangle but to save time you can print one out and use it as a template
  • Use a 1 inch drill bit to drill ta hole in the middle of the base
    • This is where the pole will go through
  • Mark the middle of each side of the triangle, this is where you will drill
    • When drilling the leg hole
Step 5: Fitting the Legs in Place
Now its time to fit the legs in place. I put the bottom nut and bolt in the leg before fitting it in to place to make it a little easier.
Step 6: Make the Handle Mount
Now onto the camera mount
  • The first thing I did was remove the straps attached to the top of the handle by pulling out the plastic piece that was holding it in
    • Then I took the bolt from my broken tripod and super glued it into the hole where the strap was
      • I reused the bolt I had from my last tripod but if you don't have one you can buy a 1/4 inch nut with 20 threads to the inch - the standard camera mount size
Step 7: Final Assemebly
Put all the pieces together and you have a ski pole tripod! Congrats! :)
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
