Skoda Fabia Mk1 LED Dashboard Lighting Conversion
Introduction: Skoda Fabia Mk1 LED Dashboard Lighting Conversion
A how-to on replacing the lighting in a MK1 Skoda Fabia dash cluster
Step 1: Getting In
Gently lift the 8 clips to remove front cover
Step 2: Needle Removal
Gently pry off the the 4 needles
Step 3: Panel Removal
Remove the front panel
Step 4: What You Are Left With
Step 5: Remove the Screen Cages and Plastic Panel Carrier
remove the cages by bending the metal prongs so they fit through the pcb then release all the plastic clips holding the panel carrier to the pcb
Step 6: Disassembly
main parts
Step 7: Lights
Marked in the picture are the bulbs you will need to remove and replace with 3528 SMD bulbs of your colour choice
Step 8: Soldering
Unsolder the old SMDs and solder in the new bulbs taking note of correct polarity
Step 9: Check
Test the board before reassembly by plugging it back into your car and reconnecting the battery and switching the lights on
'or plug it into a test rig if you have made one'
Step 10: Reassemble and Admire
Reassemble the instrument panel in reverse order of disassembly 'taking care to align the needles
I later added red mk4 VW Golf needles as seen in the illumination pictures
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    do you have a picture of better quality where are the diodes ??
    Hello :)
    Great effect.
    I have a question for you. How did you connected it for check in step 9, i mean which pins and voltage did you used? Tahnks for answer
    Just connected it back to the car
    I have already done this to my punto mk1 (changing bulbs to leds), and to grande punto as well, my next project will be a fiat linea (with the digital AC unit as well) :)
    My current car doesn't need that mod, it looks cool as it is (Hyundai FD)
    One minor advise for the 2nd step - next time use a fork instead, you don't want to bend the pin or break the needle
    Cheers, yeah I'll be using a folk next time as it'll remove the needle easier aswell, no damage was done though ☺
    They're nice the Fiat Linea, shame they aren't sold in my country thogh
    Some picture... First one is the final version with added temperature meter (needed to change a sensor in the engine and to put the instrument into its place), and the original green.
    In the mk1 punto there are no leds, it has bulbs with plexiglass, so it was a bit harder to change and to get diffused light. Today I would make it with fresnel lens from an old LCD display...
    looks great ?
    thanks, it's much better
