Step 1: Pumpkin Shopping, Permanent Marker
You'll need to hunt for your pumpkin in a place with weird-shaped pumpkins, which (as I mention in my Life-Size Skeleton instructable) probably isn't your local supermarket...
You need a pear shaped, head-sized gourd. It can be shaped like a pear or a lightbulb, as long as it's got a nice round chunk where one might keep one's brains, and a narrower area that might server as a jawbone. Often a pear-shaped pumpkin will be a bit skewed to one side: these are especially good for our sinister purposes.
Pick up the candidates. Recite some Shakespearian Yorick-related verses. Think "skull." If at some point this process gives you either the willies or the creeps, then you've probably found the right pumpkin.
Take it home and rub your hands together, cackling, and bust out your permanent marker.
Draw out your shapes, using photos, toy skulls, or actual skulls if you have them laying around.
Step 2: The First Cut Is The Deepest
Cut along the jawbone, and around the entire pumpkin. You're defining the "line" where the neck meets the skull here.
Now, scoop out the brains.
It's impressive how skull-ish your creation can look immediately after this step!
Step 3: Think "Planes..."
As you carve your skull, keep in mind that you're trying to create the illusion of depth. Real skulls don't actually have "holes" all the way through for the eyes; they have almost conical indentations that hold the eyeballs.
In "2-D" pumpkin carving, you can just cut out a hole and you're done. But here in 3-D land, you want to finesse it a bit: make angled cuts into the eye as shown in the photo. You'll still end up with a hole for the eye, but the angled surfaces you've created help to set up the other parts of the skull.
Same idea with the jaw: thinking sculpturally, use shallow cuts (you can always go deeper later) which "imply" depth, because they look like they are "in front" of other features.
Barely scrape off the skin on the highest surface of the cheekbone, but dig all the way in underneath it. there is an almost triangular "hole" created by the middle of the jaw (see photo). Again, use reference materials to get the surfaces right.
Step 4: More Planing
Get all of the surfaces to their approximate depths. Again, remember that it's all illusion: you'd need a completely solid pumpkin to be truly accurate; you're stuck with one or two inches worth of depth.
Notice: the eye hole in this photo looks kind of odd. Leave it that way for now; the final shape of that hole is where most of it's personality lives, so it's really a "final touch."
Step 5: Start Smoothing
After you have your rough shapes, start smoothing them out: When you make two adjacent cuts, you get two smooth, flat planes, with a ridge or "facet" between them. If you slice that off, you get two smaller facets...
Do that first, then use the dull edge of your knife to press down the pointed edge. Pumpkin cooperates well with this; it smooths right out and looks nice and bony.
Now, do the eye. Slight variations in the shape of the eye really affect the skull's "attitude," so carve carefully. Shoot for either good symmetry, or extreme asymmetry; anything in between sends a muddled message.
Step 6: Finish, and Display!
Smooth him out, peel off as much orange as you want.
If you peel it all off, nobody can tell it's a pumpkin... if that's one of your goals, so be it. Otherwise, I suggest leaving a bit of skin, stem... it's a few notches more disturbing that way.
Make a stand with a CD/DVD spindle, some crumpled plastic bags, and some black duct tape.
Or dangle your skull from a wire.
Or, place it on top of your complete skeleton.
Candles don't do much for it really, but that conventional pumpkin technology works too.
I've had these decay in a few days, and last a year when dried properly...
Happy Carving!
sze arteest says: Jul 11, 2012. 1:59 AM
WOW, the pumpkin scull is my next Halloween craft :)
beewhitlock says: Oct 31, 2010. 5:47 PM
Awesome instructable! It worked out fairly well for me (and I added an extra touch of my own).
mcraghead (author) in reply to beewhitlockOct 31, 2010. 10:11 PM
Looks great, well done!
mr.squeakers says: Oct 16, 2010. 2:03 PM
how hard was this on a scale of 1-10
mcraghead (author) in reply to mr.squeakersOct 16, 2010. 2:51 PM
At first it was about a 7, but once you've practiced a bit it's a 4. The tough part is the anatomy: once you have the picture in your head it's not too bad.
drummonkey92 says: Nov 2, 2007. 8:15 AM
these look awsum definately gonna try next year... or maybey try with a big cooking apple p.s. what does it say in the orange writing on the second picture of the last step? i can read'extreme pumpkin' but not whats under it.
mcraghead (author) in reply to drummonkey92Nov 2, 2007. 9:14 PM
"...a big cooking apple..."
Actually, any fruit or vegetable that's solid has a bit of an advantage over a pumpkin, because you can get the relative depth closer to reality. A pear would work great because of the fact that it is... wait for it... pear-shaped. Of course it's not easy to find a pear the size of your head.
"what does it say in the orange writing on the second picture of the last step?"
...I lifted that photo (of one of my skulls from a few years back) from extremepumpkins.com, rather than digging it up on my machine: Pure laziness really. And I can't quite make out what it says either; maybe it's just a funky dental pixellation?
ThaNorwegianDude in reply to mcragheadOct 24, 2009. 3:41 AM
its a watermark from the site
BuffaloNickel in reply to mcragheadOct 16, 2009. 4:03 PM
i think it says "extreme pumpkins.com"
w_nightshade in reply to mcragheadOct 23, 2008. 7:00 AM
Here in Scotland, the turnip is carved to make a traditional "tumshie" lantern. Hard work to carve, but long-lasting.
cowscankill says: Oct 8, 2009. 1:16 PM
Nice hand work!
St0ney says: Jul 12, 2008. 5:14 PM
Very COOL ! Agree gotta light the eyes ! St0ney stoneykins.com
fancypenguin845 says: Feb 18, 2008. 12:43 PM
if u added leds it would be really scary at night
mcraghead (author) in reply to fancypenguin845Feb 18, 2008. 2:07 PM
Yep. Maybe it would be scary enough to frighten away all of those freeloading trick-or-treaters, and I can keep all the candy for myself! BWAHAHAHAHAHAHAH!
meritsetgo says: Feb 11, 2008. 3:20 PM
For us in the tropics where is the carving a skull on a coconut video???? LOL
byoho says: Jan 10, 2008. 4:02 PM
After a bit of study, and some extrapolation, I determined that the orange text on the photo from "extremepumpkins.com" says the following; EXTREME PUMPKINS .COM
Chris Bilton says: Nov 1, 2007. 11:06 PM
Then start taking bites out of it in front of an appreciative audience; now that does look spooky
mcraghead (author) in reply to Chris BiltonNov 2, 2007. 9:15 PM
Ew, gross. Good idea.
Chris Bilton in reply to mcragheadNov 3, 2007. 2:10 AM
hey that's nothing, I've just finished carving a pentagram on the chest of a door-to-door salesman, now that IS fun
Lftndbt says: Nov 2, 2007. 1:18 AM
Damn! Now I need to wait till next year to use it... Going to make one now though for fun! Goodwork!
mcraghead (author) in reply to LftndbtNov 2, 2007. 9:19 PM
"Now I need to wait till next year to use it..."
But wait, there's always Thanksgiving! How about a skull carved into the surface of your turkey? Add that missing spark or horror to the feast! Guaranteed alienation from family and friends!
dbarak says: Nov 1, 2007. 9:36 PM
Great Instructable!
Spl1nt3rC3ll says: Nov 1, 2007. 7:27 PM
Sweet.
Brennn10 says: Nov 1, 2007. 6:52 PM
Great!!!!!! Nice, nice, job!!!!! Very cool!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
