Skyrim Map Markers
Introduction: Skyrim Map Markers
Woke up the other morning and I really wanted the Skyrim markers. Because I always wake up with Skyrim on my brain ?. So I decided I was going to make some. Didn't take a lot to make these so I figured I would share how I did them.
Now this is not limited to just Skyrim markers. You could apply this to anything!
Step 1: What You Will Need
Not a lot goes into making these.
Balsa wood, or any material that is easy for you to cut through
Paints or spray paints
Sand paper
Wood glue
Step 2: Getting the Image
Surfing the web I finally came across some images that were not pixelated.
When you find the right ones you want to use, Saved them. Open up a word document or whatever you use to resize pictures and print. But make sure all of the images are roughly the same size. No special reason, just looks good I guess.
Step 3: Cutting Out and Transferring
Now cut out the icon carefully then lay them on top of the wood. For this part I use a harder wood. Can't remember what is was though. It was laying around my art room.
Trace the outline of each. Then cut the shapes out
Step 4: Cut and Transfer One More Time
I made this a separate step because there a one additional thing that needs to be done.
This time I traced an outline on balsa wood because this time you will need to trace the inside parts of the icons. I don't know if you can tell but in the second image you can see that I pressed the inner outline into the wood. Once all this is done cut the inside parts out first (this makes cutting easier) the cut the outside outline.
Step 5: Time for Some Good Old Paint
Now that all parts are cut out, PAINT
I used spray paint just because it was faster and everything was done evenly.
Step 6: Finishing Touches
Once the paint dry, glue all the piece to its matching partner. Then sand the pieces in case there are any uneven sides.
Step 7: Get Creative
I love the way they came out but I wanted to make them a tad bit better. So I filled them with glow in the dark paints.
Step 8: Send Pictures of Yours
If anyone choices to do these or any other icons or markers, upload them and let me see
Thanks for reading my instructable!!!
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
