Slab Thickness Sticks for Clay
354
Published
Introduction: Slab Thickness Sticks for Clay
About: Life is what you make it, I make clay and wood things.
I wanted a way to have consistent slabs without having a slab roller. Using only these sticks, and a rolling pin.
Materials Needed
Wood of varying thickness- I Chose 1/8, 1/4, and 1/2 inch thick wood boards from my local store.
Tools:
bandsaw
Safety Gear
Step 1: Set Your Bandsaw and Cut the Wood
I decided on about 3/4 inch wide for the larger piece and i strip cut it using the band saw.
The narrower pieces, I just cut down the middle.
Step 2: Label If You Like
They are ready to roll!
Just slab out some clay and roll the rolling pin over the tops of the two wood pieces and you will have an even thickness. The clay between the boards should be the same as the board height.
Happy Handbuilding!
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
