iImage Information
This Instructable will show you how to turn the remains of a disposable camera into a slave flash for use with a DSLR camera or any camera with a hot shoe. It uses some off-the-shelf items that are relatively inexpensive and gives you the flexibility to have multiple flashes.
Step 1Materials
iImage Information
Off-the-Shelf Stuff:
Tools:
- drill
- 3/8" drill bit
- needle nose pliers
- soldering iron
- utility knife
- small screw driver
Consumables:
- a used disposible camera body with flash
- 4" of 22g insulated wire (and something to strip it with)
- 1/4" panel mount phone jack - solder
I got 12 camera's from the store. Only one fired and then only one time after pressing the shutter. In the end, all of them worked, if I just pressed the flash contact (the switch that should be pressed by the shutter release).
Ofcourse one can only do that after opening the camera.
If you open the camera without rubber gloves, chances you will get shocked are 99%. Do yourself a favor, wear rubber gloves
Great Job.
