Slave Flash from a Discarded Disposible Camera by wiredcur
Featured
This Instructable will show you how to turn the remains of a disposable camera into a slave flash for use with a DSLR camera or any camera with a hot shoe. It uses some off-the-shelf items that are relatively inexpensive and gives you the flexibility to have multiple flashes.
Step 1: Materials
Off-the-Shelf Stuff:
  • Wireless Flash Trigger (Search eBay for "RD616"
  • Receiver with a 1/4" mono jack (typically sold with the trigger)
Tools:
  • drill
  • 3/8" drill bit
  • needle nose pliers
  • soldering iron
  • utility knife
  • small screw driver
Consumables:
  • a used disposible camera body with flash
  • 4" of 22g insulated wire (and something to strip it with)
  • 1/4" panel mount phone jack - solder
DIY Micah says: May 13, 2010. 4:36 PM
Amazing 'Ible. I do have a question however. Do you need an external flash already or do you only need a camera with a hot shoe to use this set up? (obviously I'd need the other components)
salpeme says: Jan 12, 2012. 3:01 PM
i wouldn't connect it directly to my camera hot shoe port tho, i measured the voltage in the flash connection and it goes around 320 volts, i dont really know if that is normal, or if all flashed does the same, but im not willing to risk my camera, i would rather to use an wireless cheap shutter nd let it take the risk.
etw says: Jun 24, 2011. 8:50 AM
don't be too quick to toss the camera if it won't fire. Sometimes when the photoshop removes the film, they do it crudely and destroy the push button mechanism that then will not press the flash switch anymore.
I got 12 camera's from the store. Only one fired and then only one time after pressing the shutter. In the end, all of them worked, if I just pressed the flash contact (the switch that should be pressed by the shutter release).
Ofcourse one can only do that after opening the camera.
If you open the camera without rubber gloves, chances you will get shocked are 99%. Do yourself a favor, wear rubber gloves
Bad Maxx says: Apr 1, 2010. 6:19 PM
AWESOME! Don't know what else to say, these are my favorite types of projects... (Disposable electronics re-purposed.)
Great Job.
zack247 says: Mar 30, 2010. 3:33 PM
aesome! and i like the pic of the snail, very good pic. digital or film?
wiredcur (author) says: Mar 30, 2010. 5:48 PM
digital - Nikon D90 with 100mm prime and a 2x Maco Teleconverter - plus the flashes of course  :-)
zack247 says: Mar 30, 2010. 9:43 PM
wow. thats a real good camera. and anything is better than my samsung digimax 101, i got it in (i think) 2004 and i have had it ever since. it eats batteries like they're candy, and it doesn't take the best indoor shots either. but i guess its better than nothing!
Kasm279 says: Apr 1, 2010. 12:46 PM
My Sony DSC-P92 that i got last year takes very good pictures. Its from around 2001 and the batteries last quite a while :)
Patented says: Mar 30, 2010. 7:02 PM
Awesome ! I was bored of the only thing people where doing with these disposable camera ; A dumb tazer... But that project is much better ! Thanks !
zieak says: Mar 29, 2010. 11:41 AM
Great reuse project!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
