Introduction: Sled Ornament
Picture of Sled Ornament
This is a simple and fun ornament you can make using Tinkercad!
Step 1: Pieces Needed
Picture of Pieces Needed
(Shown from left to right, back to front)
1. Two gold "Donut Slices" by Rob Walch (Dimensions: r1=2mm, r2=10mm, arc=0.6, h=5.33mm, w=1.07 mm, l=4.37 mm)
2. Two more gold-colored "Donut Slices" by Rob Walch (Dimensions: r1=2mm, r2=10mm, arc=0.01 mm, h=1.07 mm, w=1.07 mm, l=26.67 mm)
3. Four gold cylinders (Dimensions: w=2.13 mm, l=14.67 mm, h=1.07 mm)
4. Two red "Chamfered and Rounded" by Olivierr (Dimensions: w=2.13 mm, l=15.73 mm, h=1.07 mm)
5. Two more red "Chamfered and Rounded" by Olivierr (Dimensions: w=2.13 mm, l=14.67 mm, h=1.07 mm)
You can find the "Donut Slice" and the "Chamfered and Rounded" in Tinkercad's Community section!
Step 2: Making the Rails
Picture of Making the Rails
1. Attach the 26.67 mm donut slices to the ends of the 4.37 mm donut slices.
2. Next, rotate two of the cylinders 45 degrees and attach each of them to the top of the rails as shown.
3. Rotate the two remaining cylinders -45 degrees and attach them to the top of the rails as shown.
Step 3: Making the Top
Picture of Making the Top
1. Lift each "Chamfered and rounded" 4.13 mm above ground.
2. Line them together above the two rails, with the two longer pieces in the middle.
3. You're finished! You can tie a piece of festive string around the rails to hang it from your Christmas tree.
peppypickle (author)2014-11-10
awesome sled! thanks for sharing this ornament and good luck in the contest!
ahomans (author)peppypickle2014-11-10
Thank you! :)
About This Instructable
114views
1favorite
License:
More by ahomans:Sled Ornament
Add instructable to:
