3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Sleek and stylish Ipad(and more) stand
This is a nice alternative to all the big and clumsy stands for ipad.
It took me less than 10 minutes and 2 tools to make this sleek stand
What you need:
x An Ipad
x 3 mm thick Plexiglas
x A jigsaw
x A hot air gun
Step 1Step 1
Step 1
Get your Ipad, first things first, you have to have an Ipad to build an Ipad stand
57 comments
1-40 of 57next »
Jun 20, 2011. 9:47 PMA flyin muffin says:
Good idea btw.
Jun 20, 2011. 9:46 PMA flyin muffin says:
Why is it that every post with an apple product has people arguing about which company is better? Apple lovers: not everyone likes their products, believe it or not. Microsoft lovers: you don't need to bring up this topic ever time you see someone with an apple product. EVERY ONE JUST STOP COMPLAINING ABOUT THE OTHER COMPANY. YOU ARE NOT BEING FORCED TO USE THEIR STUFF.
Jul 3, 2010. 11:44 AMmhache says:
Nice idea. Just made one. Looks great
Jun 14, 2010. 7:20 AMcaper666 says:
simple cheap and works great thanks. i made one in about 15 minutes from a 6x11 inch piece and its awesome.
May 6, 2010. 9:33 AMgabureiru says:
How did you cut the plexi????, I have tried to cut plexi but it always breaks apart.
May 20, 2010. 8:08 AMgman2000watts says:
 dremel and cut wheel! my fav tool for acrylic or plexi.
May 19, 2010. 8:19 AMit_dont_work says:
i use a band saw. if you want a very presice cut, score with a box cutter like aaron_mcg says. sit it on a level surface and run a hack saw u and down the groove made with the box cutter, it'll take some finess but will leave an easy to sand and polish cut. you can also add a ronded edge but using a round file to make a semi cirle grove in and bit of saw blade or similar thing steel, and then scratch up and down your freshly cut edge of perspex to make a rounded edge.then just polish the edge with some fine wet n dry some brasso and a cloth
May 6, 2010. 7:05 PMaaron_mcg says:
If you score your cut line with a boxcutter or exacto blade, then cut on the waste side of the score line, it will limit the amount of break-out. You can also try putting masking tape on both sides of the cut, drawing your cut line on the tape and then cutting.
May 6, 2010. 10:03 AMToddR says:
I was wondering that myself.  Instructables has some info on that if you look around.
May 14, 2010. 12:08 PMspiceyweasel says:
It's been my experience that those who despise Apple products have never used Apple products other than sitting down at a friend's computer for a minute or two. I own six different Apple products and none of them have ever crashed, malfunctioned, or simply quit working the way the PC's my family use do. The best way to prove Apple's reliability is to look at the number of ex-PC users who have converted to Mac vs. the number of Mac users who now use PC's. You really can't blame the computers....as they all sport similar hardware now; It's the Operating Systems they run. Microsoft has been attempting to clone OSX for more than a decade now and they still can't do it. So, PC users, don't blame Apple...blame Bill Gates.
May 6, 2010. 8:07 PMharuspex says:
You don't have to hate Apple or not have the money to not have an iPad. You can simply not want or like the iPad product itself. I don't hate Apple, I have several Apple products, but I don't like the iPad.
May 6, 2010. 1:18 PM300cman says:
Just go down to an office supply store and buy a business card holder. $1.99
May 6, 2010. 12:24 PMbettbee says:
To cut plexiglas, you can use a scrollsaw, jigsaw, panel saw, bandsaw, or coping saw. Leave the backing paper on, or mask as in this instructable. The slower the blade the better, as the head of friction can mess up the plexi.
Bending plexi along an axis works best if you heat only the area to be bent. Heat guns or even torches (carefully) work great. To make a bend with a greater radius, just heat a wider swath. Heating in an oven seems like it'd leave you with a very floppy bit of stuff that is hard to bend at one discrete point, but I suppose you could place your piece on two separate bits of wood or metal with the edges at the bend point. and then bend the piece using those supports. But this seems unnecessarily difficult.
For a professional look, use a flame to polish the cut edges. Any kind of torch should do - if you are using a hotter torch, just hold it further away and move the flame faster over the surface. I'm guessing even a heat gun held close enough could do this but never tried.
For gluing plexi together, do not fire polish the edges to be glued and use proper plexi solvent in a needle bottle or syringe. It's cheap.
To polish and de-static plexiglas, use brillianize. Buffing wheels and polishing compounds can take scratches out.
Just find scraps and practice with whatever tools you're using for the job, and you'll do great.
May 6, 2010. 12:29 PMbettbee says:
Correction: to cut details you ideally want a slow blade like a cutawl but you can use a jigsaw or scroll saw. For straight cuts, a fast blade is ok but you gotta keep it moving. There are guides on the proper blades to use, just google it.
May 6, 2010. 10:43 AMTim Temple says:
You're going to need to sand or router the edge to make it look decent.
May 6, 2010. 10:37 AMTim Temple says:
Try baking it at 225 on a paper towel on a cookie sheet.  It will be soft & stiff enough to bend with thin gloves.  You've got 30 seconds to get it right.  Don't let it get in contact with anything made of soft plastic!
May 6, 2010. 6:16 AMeidolon1138 says:
Fantastic.  Simple and elegant.  I've been trying to bend coat hangers into a suitable stand for days now and nothing looks or functions as well as this.  Thank you.
May 2, 2010. 10:36 AMmttrout says:
Nice idea.  Cheap too!  Might have to make one of these.
Apr 30, 2010. 9:53 AMmattnoks says:
Nice!  Don't have an iPad but I always laugh at the people who make crummy cardboard stands for something that was so expensive and nice looking.  This is by far the nicest looking stand for the least amount of money I've seen.
Apr 28, 2010. 4:37 PMit_dont_work says:
i absolutly despise the ipad. but i love how you've used perspex! reminds me of high school fabrication classes lol. i wish there was more perspex type instructables on here as its a great building material and if you look hard enough easy to find and recycle. great idea very simple and your results look very astheticly pleasing and well made
Apr 28, 2010. 6:26 PMCowpow16 says:
 i hope you know you just said "if you look HARD ENOUGH its EASY TO FIND", i just wanted to point that out :)
Apr 30, 2010. 1:59 AMit_dont_work says:
thankyou :P
Apr 28, 2010. 5:37 PMKnexFreek says:
 God i just hate pc people like you. Why do you have to DESPISE the ipad?
I mean c'mon, its just a product. Dam.
I like apple, but i don't hate pc, its just another company. WHY must you hate the ipad? i mean be mature. Im fricken 14 and i can.
Jul 6, 2010. 10:23 AMDJ Radio says:
We hate the iPad because it sucks. Plain and simple.  Apple can and should do better.
If you ask me, they could fix most, if not all of the iPad's shortcomings and keep it at the same price, and potentially make a perfect product, but they continually "add" features to their products and "make them better" each year just so they can keep selling their stuff and make more money by incrementally upgrading their products.
If they are getting close to making the product perfect, they just suddenly discontinue the line in question and start a brand new line to replace it.
Jul 6, 2010. 3:42 PMLowney says:
Whilst I see KF is overreacting slightly, I disagree. Apple start with a product that is as good as they can make. Unfortunately, Apple is EXTREMELY arrogant and refuse to have any other company input, hence no flash player etc. A lot of new features for products are user requested, and the only brand that I am aware of that they have halted (in the whole "i" series) is the iPod mini, simply because it was obsolete. So new features are actually requested by critics and users, and Apple then improve the product like that.
Jul 6, 2010. 3:50 PMDJ Radio says:
But why not put those features in right off the bat? They have discontinued other lines too, but none of the others have "i" in the beginning of their name (example: Powerbook, newton)
Jul 7, 2010. 9:19 AMLowney says:
Yeah that's my point, clearly apple are imaginatively challenged, and it's user feedback that tells them what to do next. So in essence they cannot add new features until they've released a sort of base model if you get me.
Jul 8, 2010. 7:39 PMDJ Radio says:
So their "innovation" is really a facade.
Jul 9, 2010. 2:47 PMLowney says:
Well I wouldn't say that, the original iPod was a massive innovation, and most of the advancements were down to improvements in technology anyway.
Jul 7, 2010. 8:51 AMKnexFreek says:
Ok DJ, calm down. I am an otter. A big, smelly otter.
Jul 7, 2010. 11:13 AMDJ Radio says:
Yeah that's great. Have fun.
Jul 13, 2010. 7:41 PMIAMKNEXFREEK says:
i didnt even write any of this entire conversation. someone has my account
Apr 28, 2010. 6:31 PMclemsonguy1125 says:
 I  am fan of Dell computers but I love my itouch and ipod stuff, I dont mind macs but I prefer  dells, they both have great products
Apr 29, 2010. 4:31 PMRobot Lover says:
Dells suck! Im not sorry for that they just suck!
Apr 29, 2010. 4:57 PMclemsonguy1125 says:
 Why, cause there better and more durable than apples
Apr 29, 2010. 8:24 PMRobot Lover says:
More durable, yes. Better, heck no!
Apr 30, 2010. 2:34 PMclemsonguy1125 says:
 Cheaper can do more and better, yes
Apr 30, 2010. 2:59 PMKnexFreek says:
 the discussion was about the ipad.. the ipad is cheap compared to a laptop. ipad costs 400-500
Jul 8, 2010. 7:40 PMDJ Radio says:
but then again iPads are far inferior to laptops. No multitasking, keyboard sucks, and you are locked into Apple's itunes store for software and games.
i didnt write that either
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:r0bban(Robert Kniola)
