Introduction: Sling Shot Controller for Angry Birds
Learn how to make a simple sling shot device to play Angry Birds using Arduino Leonardo. Below is the Arduino code with explanation in comments.
This code is in the public domain
Author: alpeshVitha
Date: 18th May 2013
int sPull = 0; // Start Position of the x axis
int ePull = 0; // End position of the x axis
int ysPull = 0; // Start Position of y axis
int yePull = 0; // End position of y axis
int range = 15;
int responseDelay = 1;     // response delay of the mouse, in ms
// Declaration for smoothing the y axis reading. I found them very noisy, probably because potentiometer is logarithmic in nature.
const int numReadings = 10;
int readings[numReadings];      // the readings from the analog input
int index = 0;                  // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
void setup() {
  // initialize mouse control:
  Mouse.begin();
  Serial.begin(9600);
  // Smoothing initialisation
    for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
void loop() {
  // read the initial state of sling at x axis and y axis
  sPull = analogRead(A0); //x axis
  ysPull = analogRead(A1); // y axis
  ePull = sPull; // value of x stored in ePull variable
  delay(100); // wait for 100ms for the finger to slide on the potentiometer
  sPull = analogRead(A0); // read the x axis again
  int pull = (ePull - sPull); // Delta x
   // do the same for y axis to get Delta y
   yePull = ysPull;
   int ypull = (yePull - ysPull); // Delta y
      if (sPull == 0){
           if (Mouse.isPressed(MOUSE_LEFT)) {
      Mouse.release(MOUSE_LEFT);
  if(pull>-200){  // Adjust this value based on your set up
  if(pull<200){//    Adjust this value based on your set up
  // calculate the movement distance
  int  xDistance = (pull/50)*range;
  if (xDistance != 0)  {
        if (!Mouse.isPressed(MOUSE_LEFT)) {
      Mouse.press(MOUSE_LEFT);
    Mouse.move(-xDistance, 0, 0);
  // Smoothing of Y
     total= total - readings[index];
  // read from the sensor:
  readings[index] = ypull;
  // add the reading to the total:
  total= total + readings[index];
  // advance to the next position in the array:
  index = index + 1;
  // if we're at the end of the array...
  if (index >= numReadings)
    // ...wrap around to the beginning:
    index = 0;
  // calculate the average:
  average = total / numReadings;
  delay(1);
  int  yDistance = (average)*2;
if (yDistance != 0)  {
  Mouse.move(0, -yDistance, 0);
// a delay so the mouse doesn't move too fast:
  delay(responseDelay);
azharz (author)2013-05-24
I am finding this for a year! Thanks.
azharz (author)azharz2013-05-24
Can you please add the things name that is required for this project? Because my speaker is faulty.
Strontium (author)2013-05-19
cool circuit.
About This Instructable
1,444views
11favorites
License:
More by alpesh.vitha:Pi - The news readerSling Shot Controller for Angry BirdsPedal Powered Mobile Charger
Add instructable to:
