Step 4The U-Shaped Ammo!
The materials you will need are:
2 Pliers (1- diagonal and 1- combination) - check the images below.
a thick wire (a piece can be cut from a coat hanger)
a (black) marker
Method:
1. Cut piece of wire using a "diagonal plier". (The length will vary on the size of your sling shot's pouch. Calculate it's perpendicualr height, and cut the wire about x3 the size.) - check the image when i comare the size.
2. Use the "combination plier" to straighten the cut piece of wire.
3. In the middle, mark with the marker two points which are of the same lenght of the size of your sling shot's pouch.
4. use the "Combination plier" to bend the two ends of the wire in a vertical position, slightly on the outside of the marker markings; creating a U-Shape!
(5. Cut only extra piece jotting out which makes the U unequal - optional-)
You have just made your U-Shaped Sling-shot ammo!
comments
Add Comment
Add Comment
