Introduction: Slingshot Backstop or Catch Box
Picture of Slingshot Backstop or Catch Box
I was having some trouble getting the energy and humility up to go outside and learn to hit a few cardboard boxes I kept for slingshooting, so I decided to step it up and make a bigger, more impressive target.
This way I look like I'm a professional while I learn :)
Materials
32 feet of 1” diameter PVC Pipe cut to the sizes below. (This is what I chose to use. The dimensions of your project may vary if you wish to use a different size layout. I had to buy 35 feet in order to get the cuttings worked out correctly.)
3 cuttings 4 feet long
2 cuttings 3 feet long
4 cuttings 2 feet long
6 cuttings 1 foot long
PVC Pipe Connectors
6 T connectors
4 Elbow connectors
Queen Bedsheet – Top Sheet
PVC Cement
Heavy-ish Wire
Cardboard Cuttings
Step 1: PVC Assembly
Picture of PVC Assembly
Assemble the Pipe Cuttings as follows:
Feet:
Connect a 1 foot pipe and a 2 foot pipe end to end with a T-Connector Make 2 of these.
Right and Left sides
Connect a 3 foot – Tee connector – 2 foot – Tee Connector – 1 foot – Elbow. Make 2 of these.
Back Piece
Connect a 1 Foot – Elbow - 4 foot – Elbow – 1 foot
Assemble pieces according to diagram.
Step 2: Sheet-nanigans
Picture of Sheet-nanigans
Overall, this fabric will need 3 open pockets that the 3 horizontal crossbars will be inserted in. Imagine it like a set of drapes, but instead of the curtain rod going at the top, there are also rods in the middle and at the bottom.
Here is how I made my fabric backstop.
My queen sized bedsheet had a top-folded seam when I bought it so I opened up the sides of the seam with a seam-ripper. This is the top section of the backstop. Attach it to the top of the PVC structure by threading the 4 foot PVC pipe through the looped section of material.
Next, I found the appropriate length for the lower seam.
With the sheet on the PVC Frame, I measured the distance needed from the top of the sheet around the back of the rear PVC cross bar. The goal is to sew a new space in the fabric that the rear pipe can be threaded through. The goal of the top section of material is that it will billow and slack so that ammo will not bounce off the back bar.
I chose to make this somewhere between 30 to 35 inches from the top of the sheet. It may be different for you based on your preference of how much billowing fabric you want to have draped across the top portion of your backstop.
Then, make one more seam across the bottom of the sheet by folding over 2-4 inches of fabric from the bottom of the sheet. The bottom cross bar will go through the sheet here.
Once the material is sewn, the Backstop is almost finished.
Step 3: Targets
Picture of Targets
I used the wire to make some S-Hooks from which I could dangle targets. This will work just fine with soda cans and any other smaller targets, though I will dangle them with some string so they stay in the middle of the backdrop targeting area. I am not terribly accurate yet when it comes to shooting my slingshot, but I have not had any issues with a target space this large.
I also poked some holes in a piece of cardboard and attached a page torn out of a magazine to use as a target. I will likely print out some bulls and other similar paper targets to tape to cardboard to work on more precise aim.
shodai-soke made it! (author)2015-01-15
Made some mods ... 3/4 in. diam. pipe and fittings. Glued some, used self-tapping screws on other joints to make it portable. Used spit foam pipe wrap on all exposed forward facing pipe (reduce rebounds), AND to hold the TWIN-XL sheet in place (no sewing needed). The 3/4" pipe is not as sturdy as the 1", but lots less expensive, so I had to use three cords (two from the top ELLs to the front foot, one from the bottom right foot to the across 1st joint on the left (hypotenuse of a triangle) where the sheet is held, to stabilize forward and side sway. Works perfect. This leaves the sheet intact for the wash if needed, and everything can be wrapped up in the sheet for transport. Only need a Phillips-head screwdriver to disassemble and reassemble.
DIYWEAPONS (author)2014-09-11
keep them coming!!!
mikeanway (author)2013-03-01
Very nice, I especially like the idea of using a sheet and how simple it is to construct. Great Idea. When I construct one I think i'd add some swim noodles on the front bars to get rid of some of the hard surfaces to minimize the bounce effect off the front if you have a wild shot. My 7 yr old Grandson will be using it too.;>)
LeximusMaximus (author)mikeanway2013-03-02
That's a good idea!
rimar2000 (author)2012-06-03
Very clever and echologic.
About This Instructable
12,683views
23favorites
License:
More by LeximusMaximus:Slingshot Backstop or Catch box
Add instructable to:
