Slow Brewed Cold Coffee
483
13
Published
Introduction: Slow Brewed Cold Coffee
About: A geek traveling the world!
While I love being all techie and such, some things just work too well not to be simple. Slow Brewed Cold Coffee is one of them.
Here are all the things you'll need:
  • a large container/jug
  • freshly ground coffee
  • filtered water
Step 1: The Process
While I cannot claim to be the original author of this method, I have simplified it and made it as easy as possible to do.
  1. Fill your container with filter water.
  2. Add ground coffee to water, proportional to the amount of water used. (i.e. 8 grams/2 tablespoons for each cup of water).
  3. Cover container and let it sit on the counter overnight.
  4. Filter your 'cold brewed coffee' into another container, then place in fridge.
This is as simple as you can get it. It makes for an excellent summer drink but can also be easily warmed up and flavoured to your taste.
I have noted that the coffee is much stronger with allowing it to completely soak in the water as opposed to being 'rushed' the normal way.
Step 2: Simple
Like I said at the beginning. This Instructable doesn't need to be complicated to enjoy a good, strong, cold(or warm) coffee any time. It's just simple.
    • Backpack Challenge
      Backpack Challenge
    • Stick It! Contest
      Stick It! Contest
    • BBQ Showdown Challenge
    2 Discussions
    Great Instructible but I think you're a little light on coffee grounds compared to most recipes. I've found that 1 cup of grounds in 32 ounces of water works great (your recipe calls for about half that amount). You end up with coffee concentrate that can be mixed with ice, water, milk, etc without getting too watered down.
    Also, (as a public service announcement) be aware that cold brew tends to have a lot bigger jolt than regular coffee. Even if it doesn't taste especially strong, it may have a pretty heavy dose of caffeine in it, so start slow! My chemist friends tell me that caffeine leaches into the water much more readily than the coffee flavor.
    Thanks for posting!
    Thanks for the comments. Yeah, YMMV should always be a caveat. And yeah, it is a bit more of a kick for sure. Thanks for the extra warnings.
