3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Slowflow watering decanter
This improvised watering decanter is perfect for watering small plants that don't need a lot of water but do need it regularly. It's simple and is made of dirt-cheap items that most people probably already have around their house and tools that most people already own. It's small so it can easily be stored at your desk where you work or in a small space out of sight at home. it's also fairly safe and doesn't spill much if it falls over while full - though it will spill a little.
I originally put this together because I needed a bottle with a narrow spout which would make it easier to get the water into the narrow gap at the end of seedling trays. Since I'm starting them early I have to keep them inside which for me is in front of my big bay window in my nice carpeted living room where there's plenty of light. I like to water them from the bottom which means pouring about a pint of water through a half-inch gap at the end of the tray and hoping I don't spill any.
This introduces two issues which I solved using this decanter: accuracy and quantity. Since the bottle is clear and already close to the right quantity for one tray it makes it easy to measure the amount of water I'm adding to each tray. Granted this creates extra work since I'm constantly shuffling back and forth to the kitchen for more water. Perhaps this calls for a large watering container: maybe something along the lines of a two-liter Coke bottle.
Secondly, this is much easier than just pouring the water on my plants at work. I have more than a dozen plants at my desk, some of which dry out before others. Most of the plants are large pots that only need water once a week and the whole batch can be taken care of in two or three trips to the restroom sink.
I also have several small cacti which dry out completely on an almost daily basis. Instead of running them to the restroom sink every day it's nice to have a watering bottle at my desk. Plus they are crowded together on a tray and the long spigot makes it easy to get to all of them without spilling any water. Finally, and most importantly, the water flows slowly which keeps me from overflowing the pots and making a big mess.
The real reason I made this is that, in true Instructables spirit, I had some spare time, love putting things together, was thrilled at how well all the parts integrated, and hoped somebody else might get some use out of the thing. Remember, this is my first instructable. Granted it's not a Traditional Polynesian Ice Canoe - I wish I had some ice nearby so i could try that - but it was fun to do.
Now...without further adieu...
Step 1Gather Materials
Gather Materials
The following materials will be needed for this instructable.
  • A beverage bottle of your choice. I had lots of water bottles on hand so I used one of those.
  • Two flexible drinking straws. If you want faster water flow then you can get larger diameter straws such as those you get at restaurants. The only problem with those is that you loose the flexible joints which server to help secure the straw to the bottle in this case and also let you flex the spigot straw for easier watering.
17 comments
Nov 29, 2009. 7:27 PMcrossless says:
 I have use lot of soldering iron to make holes in thick plastic to get air holes to containers for snails home. So you could use that as making hole or with candle flame heated sharp knife.If you can use some force with stinger what is use to make holes for drill starting point in material that makes nice hole too. You need use air-conditioned place to melt plastic. I'll think I try this one I need often some small bottle to water snails peat. :)
If you get your hand long neck bottle, you cold try to make holes on the neck.
Jun 19, 2007. 10:54 AMChanio says:
Caution!
Please, allow me to suggest a safer method ('though no one knows what is really safe)...
Use any rounded metal of that size and heat it until red hot. Then just be careful and touch the plastic lid with it. It is going to melt as butter. So, be careful to just melt the size that you wanted to gain. Or a little less, since there might be a little of melted plastic all around the edges. You should then cut those melted edges when they are not so hot. And later, use some cold water to see if the hole was what you have expected.
It is very tempting to use the drill but many times, the lid would slip and start spinning at high speed.
That is very dangerous...
Sep 23, 2008. 12:45 PMCaseyCase says:
Caution! ...very dangerous... Worth repeating. LOL!
Jun 22, 2007. 12:42 PMtheprofessor says:
use a clamp if you drill.
Jun 19, 2007. 11:15 AMChanio says:
Very nice photos!
Clear and big enough to self explain themselves.
Feb 20, 2007. 4:56 AMgowithflo says:
I'm going to do this . . . .
Hey just started a gardening group. Add this instructable please!
http://www.instructables.com/group/reapwhatyousow/
thanks
Feb 8, 2007. 11:42 AMcrapflinger says:
very well written and well thought out...very well documented (your "gatorade" pose is more of a napoleon dynamite pose though *gosh!*) i would imagine with slight modifications you could actually make this process into more of a "trickle feeder" for when you are out of town....maybe by making the air return portion a MUCH smaller diameter?
Feb 7, 2007. 1:47 PMcanida says:
Nice! I always made a terrible mess watering overhead plants, especially spider plants- without a small spout it's easy to water the tops of the leaves, which then dump the water back onto your head. Your solution is easy, cheap, and involves recycling rather than buying more plastic crap.
Feb 7, 2007. 12:10 AMskids927 says:
what is the benefit of this? why cant you just pour water the normal way?
Feb 7, 2007. 11:29 AMewilhelm says:
Thanks for the nod to my ice canoe! In my opinion, this is definitely as much as an Instructable it is.
Feb 7, 2007. 1:03 AMtrebuchet03 says:
The same reason why so many people don't feed their dog the normal way every day and buy an automatic feeder ;)
Feb 7, 2007. 2:13 PMShark500 says:
this is not an automatic watering bottle. this just uses the second hole to equilize the preasure and give a nice solid stream like with a small watering can
Feb 7, 2007. 5:43 PMtrebuchet03 says:
No I understand :) My point was convenience ;)
Feb 7, 2007. 12:23 AMbinnie says:
if you go on holiday and your plants need water, you cant be there to do it this could be used for that or just to slow teh water down dramaticly
Feb 6, 2007. 10:55 PMjbeale says:
This is at work? It may seem funny... maybe I have no sense of humor, but... your hazard placard indicates a substance that is extremely flammable, and also toxic, and chemically reactive, and incompatible with water. I don't know where you work but at most places I've worked, the safety guys would take a very dim view of keeping anything labelled that way outside of a secure chemical storage area.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:gzusphish
