3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Small 110 volt arc welder (NYDG)
Im going to write a ton of Instructables on how to make Not your Dads Garage but work area designed for the future of builders. I will work in an evolution process to more and more complicated project, using project in past Instructables to help current project, assuming you have access to your dads tools (Hammer, Screwdriver, Saw, Drill,)
We will start by making a 110 Volt Arc Welder, 220 would be nice but most Instructable starters dont have a 220 outlet. It needs a little solder so you will need a soldering iron.
Step 1Building the 110 Volt Arc Welder Housing
Make sure its strong, it will way more that 100lbs
Material
1. 2 x (30 inch x 24 inch x 1 inch) SIDE
2. 1 x (25 inch x 36 inch x 1 inch ) FLOOR
3. 2 x (24 inch x 36 inch x 1/2 inch) Levels
4. 4 x (36 inch x 4 inch x 1/2 inch) Walls
5. 1 x (37+ inch x 2 inch Dowel) HANDLE
85 comments
1-40 of 85next »
Nov 3, 2008. 5:35 PMdciocoiu says:
the microwve transformer emits Gama rais not electricity. dosent it ?
Dec 18, 2011. 8:48 PMkj4sqr says:
no the rads come from the emitter and it is not gama it is microwave waves
http://www.icta.mu/radiocommunication/frequencyplan.htm
simple chart i use
Oct 24, 2009. 8:39 AMtoogers says:
gamma rays? that would mutate the food. now i'm off to "shoot gamma rays at food."
Oct 24, 2009. 8:41 AMtoogers says:
Jan 21, 2009. 7:15 PMlasermaster3531 says:
Firstly, what are "Gama Rais"? Secondly, the microwave transformer does not give off anything but electricity and a little bit of heat. Thirdly, if you mean microwaves, the magnetron is what makes them and drools them into the cooking chamber.
Mar 14, 2009. 7:13 PMdpsilver says:
the magnetron makes microwaves not gamma rays
Jan 27, 2009. 1:11 PMWesley666 says:
He means Gamma Rays and no it doesn't. It provides power to the magnetron which creates MICRO waves which heat water thus cooking food.
Nov 26, 2008. 5:27 PMSaint_Awesome says:
The transformer puts out plain old electricity, it's the 'magnetron' that puts out the microwaves that cook the food.
Dec 18, 2011. 8:42 AMgermeten says:
I don't mean to be critical, but the project can be built a lot simpler. If you take a MOT (microwave oven transformer) and test the turns ration you'll find it's about 1:18. Turn it around and it's 18:1. So if you start with 120V you'll be stepping it down to 6V (measure it with a volt-meter, carefully!) Yes it will be AC but arc welders typically have a DC and AC mode. You can add a bridge rectifier for DC if you want to. Two reversed MOTS with parallel primaries and series secondaries will give you 12V output. Yes you can add more MOT's for more current output. Using a dimmer switch will reduce your power output because dimmers only use the trailing half of the wave, and dimmers don't really like inductive loads. They create "noisey" spikes that tend to heat -stress transformers, but only on half as long.
Aug 4, 2011. 3:10 PMjlang2 says:
I like popcorn but I disagree that popcorn is better than a welder. Popcorn is nice; welders make nice stuff. Nicer than popcorn.
Jun 11, 2011. 5:10 PMteche says:
so to make a welder i only need an instructible on how to build a soldering iron :)
Nov 22, 2010. 1:56 PMCowGuy says:
The secondary coil will be the one with the thinner wire correct?
Nov 22, 2010. 2:02 PMCowGuy says:
These are my transformers, the top ones are the secondary and bottom ones primary or is it the other way around?
Dec 2, 2010. 10:28 PMEmiliogiz says:
Yup, thats right. The top coils are the secondaries, which you need to slice off. The bottom coils are the primaries, which you should not touch or damage in any way.
Good luck!
Jul 15, 2010. 1:03 PMjaymanx says:
did that just say 10 microwaves? lol
May 1, 2010. 8:34 AMshortyjk95 says:
This is a little confusing on how to make it because 220 do the same thing on how to make it and I don't get what you are doing different can you help?
Feb 11, 2010. 9:19 AMewitwins says:
Wait, so what sort of material did you use for your Welder Housing? It looks an awful lot like you used wood...
Feb 7, 2010. 10:10 AMguds777 says:
 the outlet for the owen in your kitchen is much hier amps, maby 40 amps.
Sep 3, 2009. 6:22 PMdynamodan says:
Thanks for crediting my site. The correct url to the article on my site is here:
http://www.dansworkshop.com/electricity-and-electronics/homebuilt-arc-welder.htm I originally came up with these plans and photos about 10 years ago and I also sell a downloadable pdf with even more photos and instructions.
Dec 4, 2009. 10:36 AMjuanoporras says:
thanks dynamodan, I saw your site before this instructable and I recommend it!, its much clearer I believe.
thanks to Kdemon too for sharing that info here!
Dec 4, 2009. 8:36 AMjosephprivott says:
Nice writeup, Could you elaborate on the triacs more? I'd rather have a specific part than hunt around and get something that is an ill fit. What is your work in progress? I see it's on a swage block...
Jul 18, 2007. 1:31 PMDeusXMachina says:
Umm, I might be missing the boat, but what's the point in rewiring a step up transformer to step down? Why not just run it backwards? You'd end up getting about 3.6v at the electrode. Although, I guess the thickness of the secondary-now-primary windings would be somewhat troubling. It seems like it'd be a lot easier to take four or five transformers, link up all the secondaries (from the microwave point of view) in series and then put all the outputs in parallel.
Sep 3, 2009. 6:19 PMdynamodan says:
Yeah you are missing the boat. The original secondary windings won't make a good primary, and the original primary isn't near heavy enough either. Trust me, I've tried it.
BTW these plans are ripped off from my site
Jul 30, 2009. 7:09 AMbylerfamily says:
Well,that would lower the voltage,but amps is what is needed for welding so it would not weld much more than a pop can.
Mar 18, 2008. 12:19 AMPrometheus says:
A reasonable idea, but hooking the secondaries in series and then the primaries in parallel will continually drop voltage through each transformer. Also, the transformer secondary with the greatest impedance will suffer the brunt of the current. If you are going that route, have several matching transformers and hook them all in parallel. However, 3.6V is not enough for even spot-welding (which you'll need at least 6.3V @ 600A+ for). For AC, you'll need at least 80 amps to be even remotely effective.
Jun 2, 2009. 5:40 PMM4industries says:
Electronical?
Jun 10, 2009. 2:27 AMSyncubus says:
Electronical: adj. of or relating to the sound one emits when becoming part of an electronic circuit.
Jun 10, 2009. 3:40 PMM4industries says:
Hahahah!
Jun 7, 2009. 5:03 PMMetalcaster14 says:
Hmm interesting... I'm 14 and my dad has been in my workshop twice. I bought all my tools with money from yard work. My favorite tool is my drill press! I bought it at a discount tool outlet for $60!
May 22, 2006. 10:20 PMPrometheus says:
Erm...Sure most "instructables" don't have a 220V outlet, but even fewer have a 120V 100 Amp source either...
Jun 5, 2009. 7:25 AMnickajeglin says:
All that you need to input into the transformers is the standard ~15 amps from your wall socket. The purpose of the re-wrapping the secondary windings is to lower the voltage and raise the amperage.
Mar 17, 2008. 1:07 PMcomputerwiz_222 says:
In my city, the houses that run christmas lights to the max they can handle hire the electrical company to install an extra 100 amp service. The houses here are usually 50 or 100 depending on the age of the house. No one has a single outlet in their home that is capable of 100 amps. The most is 15 or 30 (maybe)
Jun 29, 2008. 1:34 AMDerin says:
WE HAVE 200A 380V TRANSFORMERS THAT FEED A WHOLE STREET AND MY LAND OWNS ONE
it is nice having 76kW at your disposal
did you know the transformers explode in case too many amps get pulled?(only the old types without a reset lever)and the new electronic one asks for a password or pulling of a lever for reset of internal breaker
Oct 24, 2009. 8:35 AMtoogers says:
hah, it's fun reading the subscript in a whisper, and the caps and bold in a yell.
Jul 1, 2008. 12:01 AMPrometheus says:
Chill with the bold large type, that's just as bad as all-caps, maybe more rude. Please stick with the site's basic format. Good for you that you know HTML, noone cares. Also, transformers don't ask for passcodes, control panels do, and no mains transformer is properly-installed without a breaker. Transformers blow-up on the pole because the circuit is compromised earlier in the circuit than the intended protection, such as an insulation failure right where the feed comes into a building. Others explode due to improper maintenance, rebuild, or configuration mistakes, or from people typing in large and obnoxious bold print on a forum for no apparent reason.
Jul 1, 2008. 12:28 AMDerin says:
ok ok correct it was the control panel for the transformer well yes but the electric company said it explodes because it is also a fuse,the newer ones have a lever to pull to reset and finally,I have seen a breaker box beside the transformer with the wire running into it
Jul 1, 2008. 6:35 AMPrometheus says:
I apologize, I came down hard on you, it';s just the moderator in me. I've admined/moderated many forums, so I snapped on the etiquette you used. You seem to still be a good guy, so I'm letting it go as a honest mistake. Anyway.... The breaker-box may have been a cut-out (knife-switch) as a manual disconnect (for service repairs/inspection). Mains transformers are required to have a breaker or other over-current device between them and the load, some of which are not easily-recognizable to a layman as the familiar devices due to a differing construction. I agree to what you have seen, but interpretation relies on a shared observation.....meaning that if I saw it as you have, I could name what you have seen. In extremes, the "high-side breaker" (supply-side) will blow explosively, because it is open to the outside air and installed to protect the source, but keep in mind that this same reaction is enclosed on a 100-amp+ breaker when it trips as well, also trying to protect it's source. On average, there are over 40 breakers from the power-plant to your appliance in place to protect the higher circuits from an overload. Without them, one short in a domestic home would black-out a city-block or burn it down. Only two breakers separate an appliance from your mains, the remaining 38-average are on the poles leading to the power-plant, and within the plants themselves. Overcurrent devices in a circuit work on a hierarchy, which is why you have a dozen breakers for your home, and then you have one "mains" that will kill power to the whole structure if it trips or is toggled. Every domestic and commercial building, regardless of size, has this mains, which almost never blows under normal circumstances. This doubles as a "cut-out" when servicing or reconfiguring the structure's main wiring. All power-distribution circuits work on a "tree" structure. The trunk (mains) is your power-source, and there are "branch" circuits. To detail this structure in a post is impossible, but just in your home, your trunk line comes through your "mains breaker", and then feeds the branch circuits for your individual areas of the house, and further branches are done even per room for multiple outlets. Some branches split several times, some do not split at all, such as your heavy-appliance circuits like your range/dryer/clothes-washer outlet/dishwasher/water-heater/food-disposal/other hard-wired appliances. In light of this project however, an illegal tap to the mains (after the mains breaker please...for your own safety!) while managing your power-consumption of the residence as a whole could make this work. Your trunk load can be determined by yo7ur mains breaker, generally 150Amps for your average 1500 sq. foot house, but this estimate is very vague, check your actual mains breaker and your home's wanng health before proceeding.
Jul 1, 2008. 8:50 AMDerin says:
ohh no prob noo not a blade switch (i think) ok and it is something like the picture correct ok then no it will not be illegal since it is mine Thank You for telling these facts and here is the picture:
Jul 1, 2008. 8:51 AMDerin says:
and plus,I will not do this project
that image was a bug
1-40 of 85next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Kdemon
