We will start by making a 110 Volt Arc Welder, 220 would be nice but most Instructable starters dont have a 220 outlet. It needs a little solder so you will need a soldering iron.
Remove these ads by
Signing UpStep 1Building the 110 Volt Arc Welder Housing
Material
1. 2 x (30 inch x 24 inch x 1 inch) SIDE
2. 1 x (25 inch x 36 inch x 1 inch ) FLOOR
3. 2 x (24 inch x 36 inch x 1/2 inch) Levels
4. 4 x (36 inch x 4 inch x 1/2 inch) Walls
5. 1 x (37+ inch x 2 inch Dowel) HANDLE
http://www.icta.mu/radiocommunication/frequencyplan.htm
simple chart i use
Good luck!
Wait, so what sort of material did you use for your Welder Housing? It looks an awful lot like you used wood...
http://www.dansworkshop.com/electricity-and-electronics/homebuilt-arc-welder.htm I originally came up with these plans and photos about 10 years ago and I also sell a downloadable pdf with even more photos and instructions.
thanks to Kdemon too for sharing that info here!
BTW these plans are ripped off from my site
it is nice having 76kW at your disposal
did you know the transformers explode in case too many amps get pulled?(only the old types without a reset lever)and the new electronic one asks for a password or pulling of a lever for reset of internal breaker
