This instructable has been removed by the author.
18
comments
Add Comment
I was checking out some of your flickr pictures and noticed that you had boarded over the spot where the bucket of water used to sit. You said the chickens liked it better this way.
So what do you do for a waterer? I also noticed that you seem to have moved the location of the feeder. I'm just curious to know before I get to those steps in my project. Thanks!
The feeder hasn't moved, there's simply a second feeder in the coop. I keep both feeders filled, and this works out well, when the girls are playing "who is top hen" games.
Don't be afraid to modify the design if you see areas of improvement! And share those ideas here!
One other change I might point out - the vinyl roofing is OK, but after having this up for a few months, I don't think the roofing will last. It's already slightly warped in some spots and while it's still keeping out the rain, it looks ugly. If you are ok with the extra weight, or don't plan on moving the tractor often/ever, you might want to consider using a metal roof. It's cheaper, more durable, and will keep the sun/heat out better in the summer; on the other hand, it's heavier.
In retrospect, I could have made most of the non-supporting pieces from furring strips (1"x2") instead of the square pieces (2"x2") and saved some weight without really compromising stability or sturdiness, and this would have allowed me to make it a bit bigger too. But also, I wanted it no wider than 3' so it will fit on the walkways in my garden better.
One other consideration, is I'll be removing the hardware cloth on the front side below the two handles with the intent of putting in another door to which I can attach a longer very portable run (probably built with furring strips and chicken wire and held to the ground with stakes through eye bolts).
Be sure to post pics of yours so we can learn from your design improvements!!
Nice coop, though ;-)
