Remove these ads by
Signing UpStep 1Stepping Down the Wall Voltage
These transformers that I bought did not really have any information provided about them, and I would guess that any scavenged parts would likewise be as much a mystery. The primary side was easily identifiable by the heavier gauge of wire. A scavenged plug was soldered onto the primary, and the connector was lopped off of the secondary, as I wouldn't use it anyways.
An important thing to thing about, if you get any say in the transformer that you are going to use, is how much current that you are going to draw from it. Size seems to be an indication of how much you can draw, but here, if it isn't listed somewhere, I usually go ahead with it and check to make sure it isn't heating up too badly at the end of it all.
Any Time You Are Plugging Anything Into the Wall, Be Extra Careful About Where You Put Your Hands, and What Conducts Electricity!!!
Like the 7805 regulator which is the 5 volt voltage regulator but there are other ones that can output a lower or higher voltage, but the input voltage has to be higher than the output.
V=IR??????? But when you cant predict the current???
you might want to add a heatsink in with the regulator.
AM Claussen, Mexico City.
Yeah, I'm a wet blanket :-)
