Small Pocket Knife
1,242
28
Posted in WorkshopWoodworking
Introduction: Small Pocket Knife
About: I hope i can show you that you really dont need to be a master craftsman to create and build great projects, and hopefully inspire you to start making yourself. I will try upload a video every Monday but du...
I Had an old multi tool that i never used , and never liked.
But i needed a small knife, so i cut the blade out of it and bought a 4mm steel rod.
Thats it , just throw in some scrap wood and i have a small knife!
Enjoy
Step 1: Scrap Wood, Knife Blade and Steel Rod
This is all you need, just make sure the steel rod is the right size for the hole in the blade.
Step 2: Cut Down to Size
To get the wood down to size i just ripped it down the middle and cut it down to a rough shape.
I also cut a small piece of the rod off making sure it would fit through both sides of the wood and the blade.
Step 3: Smooth Out Faces
Now i had my rough shape i wanted the glue joint to be minimal so i smoothed the faces of the wood down and cut a small strip off wood to act as a filler at the bottom of the knife.
Step 4: Plane Down to Square
I planed down the filler strip to the same thickness as the blade and planed the sides of the knife level.
Step 5: Test Fit and Trim Again
Once everything was ready i test fit all the pieces and realized the wood was still to big so i trimmed it some more, again planing the sides level.
Step 6: Hole for the Rod
Once everything was ready i drilled a 4mm hole where the rod would be, through one side of the wood and just transferred the mark and drilled the other side out.
Step 7: Glue Up
To Glue it all up i 1st glued the filler piece in while the blade was in the right / closed position so everything was where it needed to be.
After he glue had half dried i glued the other side of the handle on making sure it was all level and in the right position.
I also filed out a small grove so i could fold the blade out.
To keep the rod in place i just used a small amount of epoxy, trying my hardest not to get it in the blade so it can still fold easily.
Step 8: Sand and Finish
Once everything was dry i hand sanded at 80 grit, 180 grit and 240 grit.
To finish i just used some spray lacquer and sanded at 500 grit between coats.
I ended up putting 3 coats on to finish.
Step 9: Job Done
Thats it, job done.
A nice little knife, made out of scrap and a steel rod that cost £2.00
I Think its great and exactly what i wanted.
As always i hope you enjoy!
Watch the full build here -
https://www.youtube.com/channel/UCRMjvilGRdZxHqr34QKzB_Q
Follow me on Instagram-
https://www.instagram.com/ggwoodprojects/
Support me and my projects (no pressure)
https://www.patreon.com/GGWoodwork
I'd love to hear any comments.
Thanks
GG
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
