loading
Step 3: interface the timer to the LED driver
Next, interface your 555 timer circuit to the Buck Puck LED driver. This is easy. Just put a jumper wire from pin 3 of the 555 to the control pin of the Buck Puck.
I would wait to attach the Luxeon V to the driver yet. If you power it up, and it's not heatsinked, it can go into thermal runaway and melt itself down.
Note that the ref pin is not used.
My question is if you can simply bypass the 555 circuit with a 2-way switch to have a steady on option? flip one way to strobe and the other for steady on?
i want to make a cheap led strobe kit. i want the lights to be bright but i just cant figure out how to make the circuit work. can some one help? please
can i use the simple led driver as seen the led driver instructable which consists the LM 317 voltage regulator coz i am unable to obtain the led driver buckpuck. have u any replacement or alternative for that device????
Why is the LED Driver Puck Buck for? Is it needed?
It regulates the power to the LED, without it the LED would burn out pretty quickly. The 555 circuit is to make the LED flash.
By heatsinked are you referring to the Buck Puck LED Driver or the Luxeon V?
The driver is connected to the altoids case, which acts as a heatsink, so he means the led itself.
im at a loss here. Alot of steps seemed to have been skimmed over or skipped completely.
It's not that it's incomplete, it's simply not very detailed. For example, one of the steps is "Build a 555 astable multivibrator circuit". Also, the steps are somewhat self contained, just showing an electronics schematic, and trusting you to figure it out from there. It does require some prior electronics experience, and is not a beginner project.
How much do each of the parts cost, and is there a good website to order them?
is there a reason why you did not take advantage of the 5V REF supply integrated into the buckpuck?<br>Was it because of the current threshold being too low to adequately feed the 555?<br>Would the LMC555 work better due to lower current consumption?<br><br>thanks :)
yes.... with the 330 Ohm resistor the led will not draw much current or be too bright and the 555 is protected from overload....in step 2 the 555 is connected to the driver with no resistor and the driver feeds the led with no resistor needed...but if you don't remove the original resistor and led no damage will occur... <br />
nice project but....not&nbsp; 'the most powerful led available' , 100w leds have been around for quite awhile ( search ebay...'led 100w')....and now in many colours &nbsp; <br />
i think your 555 schematic in the instructable is fudged up. it shows a diode, not on the parts list, a 4.7K resistor (wasn't that supposed to be a cap?) and the value for your pot is marked incorrectly (100K or 1K?). I'm bailing on your schematic, and trying toddj's next.
The buck puck has a maximum strobe rate of 50us. if i wanted to use this for stop motion video, and trigger it off of sensor how would i advance / delay the ttl pulse for fine adjustment? Thanks!
Like this?
I want to build this circuit but there are a couple of things I don't see explained on the schematics. In step 2 the completed 555 astable circuit shows an LED connected between pin 3 and pin 5 etc. of the 555 IC. What happens to this LED when the astable circuit is connected to the Buck Puck? Is it eliminated along with the 330 Ohm resistor? Thanks, Ed65
what if lds are connected directly to the battery?
depending on the kind they would either shine bright or burn out.....
And, is the control pin kinda like the base on a transistor, a sort of switch?
whats the difference between a boost and a buck driver?
Hey, guys this is a nice simple circuit so i decided to make it. My problem is that the light just stays constant. There are no solder bridges or short circuits and i have replaced the 555 timer. Any ideas?
Using this exact circuit with the 1A controller, what is the flash rate on the LED? Thanks.
With the 555 circuit shown, you're not getting anywhere near the full drive the LED is capable of handling - about 20ma, or what a garden-variety LED will take. Ya should try adding a driver transistor and a MUCH lower resistor value than 330 ohms. By the way, many 555 versions won't work with this circuit. If anybody has problems, try reconnecting the resistor-LED string between the positive supply and pin 3, with the anode connected to +6V (LED diagram "pointing" away from 6V). By the way, this circuit will work up to 30 volts altho the resistor may get hot.
I just read your post as I was wondering if this could be used in an automotive application. 12V vs the full 30V I guess it can handle it. Thanks,
It has 9 volts running into the buckpuck, hence full power to the led, (if the battery will flow enough amperage),.
how`many`flashes`per`second`can`you`achive
I found it. I just had trouble figuring out how to enlarge the schematic on the 555 so I could read it. sorry. cr
I did not see where the capcitor is being connected? Can someone help?
You can eliminate the buck puck and get higher light output if you have the 555 switch a transistor to dump a capacitor directly into the luxeon. LEDs can handle much higher currents and voltages if they're short pulses. Just don't blow your luxeon. If you want a real xenon strobe, <a rel="nofollow" href="http://kickme.to/lightningstalker">http://kickme.to/lightningstalker</a> has one. It can be made small, but needs to plug in though.<br/>
cool, can u make a larger version too?
No that would be called a "big strobe light" This is the "small strobe light"
Hahaha.
that would be sweet to mix that and the altoids belt buckle and make a strobe lite altoid belt buckle!! i am defiantly doin that!
This is a great instructable I am defiantly going to build it, but how long does the battery last?
You'll rapidly approach the point at which a 9V battery just won't put out enough current. (have you measured how much the circuit actually puts through the LED? I'd be impressed if it manages the full 5W!)
I agree I don't think the battery will last long at all with 1amp being pulled from it even with the light strobing.
The 3021 part (white square) is an switching constant current LCD driver module that is nearly ideal for driving LEDs. The 555 is just providing the strobe pulse. If the 9V battery can hack it, this should drive the LED at max power and do so with maximum efficiency or battery life. Take a look at the driver modules at the link below.<br/><br/><a rel="nofollow" href="http://www.theledlight.com/luxeonled_drivers.html">http://www.theledlight.com/luxeonled_drivers.html</a><br/><br/>David<br/><a rel="nofollow" href="http://www.uchobby.com">uC Hobby</a><br/>
About This Instructable
101,657views
97favorites
License:
More by shawninsicily:Small Strobe Light
Add instructable to:
