Small Wooden Stool
Introduction: Small Wooden Stool
This is an Update of a previous Instructable:
I still had the same 4x4cm beams left from the pile my dad provided for me, i just keep on going!
The idea came from the bench, i made a stool that is half the size of the bench, but follows the same type of building and style.
The used tools:
-A screwdriver
-A Radial Saw( love it ! evey cut is straight!)
Used materials:
-4 x 4 cm beams
-wood glue
Step 1: Cut Your Wood
This step is very simple.
Cut the beams to length with the radial saw.
I followed the same style and dimensions as the bench, but i had to remind me that the stool is half the size.
Step 2: Screw and Glue It Toghether
Just as in the previous instructable, glue every beam together and use 2 screws every time.
Please make sure the surface you work on is flat and free of dirt.
Step 3: Add Reinforcements
The screws i used where a bit short so just to make sure the legs don't fall of when you move the stool, i used the same reinforcements to reinforce the legs.
The stool is quite heavy so a lot of moving is not necessary.
But it gives a nice ,robust and solid result!
I made one in just an hour, whenever i have a free evening, i will make another one.
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    looks good. I might have 45 the boarder of the table top but simple and clean. I've been looking for a project to use up some of my smaller boards
    Thank you. I just sanded a small amount of the sides so mo hard edges when ypu sit on it
    If you look at tje other instructable perhaps you can find a sketchup file to give you an idea.
    This looks very nice. Matches the other table you built very well! Thanks for sharing this!
    Thank you! I am very proud of the results and hope to make more!
