3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Small computer prank
Basically we are going to end explorer on the target computer, in the final step I will also tell you how to shutdown another computer if both are on the same network.
Step 1Open task manager
open task manager
press Ctrl, Shift, and escape or use Ctrl, Alt, Delete command and bring up task manager
8 comments
Jun 17, 2010. 3:43 AMjames.mcglashan says:
(Super-Key = Windows-Logo) + R; "explorer.exe"
Aug 21, 2009. 2:11 AMRedFlash says:
Some computers restart explorer.exe when it is terminated or crashes. My school computers do
Jul 28, 2009. 8:49 PMBholoo says:
I know one! This will make all the icons disappear off the desktop. XP: >Right click in an open space on the desktop > Go to the submenu "Arrange Icons By" and then uncheck "Show Desktop Icons" VISTA >Right click in an open space on the desktop >Go to "View" and then uncheck Show desktop Icons
Feb 11, 2009. 3:37 PMBatryn says:
Can you undo the task bar thing?
Mar 12, 2009. 11:55 AMkwah says:
To 'undo' it, you would need to open Task Manager (Ctrl+Alt+Del) and open 'Run' by Clicking 'File' -> 'New Task (Run...)'. When the Run box comes up, just type in 'explorer.exe' and click OK. This will restart the explorer shell and bring up the taskbar & start menu again. Some of the icons in the task tray (the area next to the clock on the task bar) might not come back up; this is normal so don't worry - most will reappear if you logout / login. If not, a reboot (switch it off and on again) should work. Overall, good step by step guide using images but it could do with more detail.
Feb 10, 2009. 5:45 PMBatryn says:
is there any way to undo it?
Feb 21, 2009. 3:30 AMpunkatsub says:
if you want to undo it all you have to do is click file, run, then type in explorer.exe, it should fix it
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Dms12444
