Step 3Finishing the base
The finishing process uses ammonia as a wood dye, and tung oil to seal the wood and add a bit more colour and depth to the grain.
No VOCs or other toxic waste products are emitted.
DETAIL:
Following some suggestions from Fine Woodworking Magazine, George Frank's "Adventures in Woodfinishing", and some simple experiments, I found that I was able to get some great effects from using ammonia to stain the oak. Namely, the process accentuated the grain and character of the wood, and gave it a lovely colour.
In a nutshell, it requires exposing the wood to the ammonia vapour. I found that a 24 hour exposure was sufficient to get good results.
You will need a plastic container, with a tightly fitting lid, that is large enough to hold your work.
Pour some ammonia-based household cleaner into the container, enough to barely cover the bottom.
Since the wood should not come in contact with the liquid cleaner, place the work in the container on some form of stand. Keep in mind that the areas that make contact with the stand will not be stained evenly.
Close the lid tightly to prevent the ammonia vapours from escaping, and wait about 24 hours.
There are two significant advantages to using the ammonia vapours:
1. The wood grain is not raised in the process, so no sanding is required afterwards.
2. The vapours penetrated to approximately 1/16" in 24 hours. This bodes well for longevity of the finish. Any scratches and dents, even deep gouges, will not expose lighter wood.
After removing your work from the dyeing container, wait another 24 hours for the absorbed vapours to escape from the wood.
(The leftover cleaning liquid can go back into the original bottle.)
Now it is time to apply the tung oil.
All the books specify using lint-free rags to apply oils; I ignored this advice and regretted it. Do not use cotton flannel.
Take your time to allow the wood to absorb the oil as you apply it (especially to the end grain), then wipe off any major excess before leaving it to dry.
One coat is sufficient to enhance the colour and depth.
If you want the finish to build on the surface of the wood, you will need to apply additional coats of oil. You must wait 24-48 hours before applying a subsequent coat.
Add Comment
