Small electric fan from spare parts.
Step 1: Parts
What you will need:
- small electrical motor and its power supply (I used a 12v old typewriter motor)
- switch
- bridge (4diodes in case you have an AC power source)
- wire coat hanger
- 2 hose clamps
- bit of rubber tubing to fit over coat hanger wire
- a plastic case (vhs, dvd, console game)
IW5 Industries says: Sep 10, 2008. 6:49 PM
small fan? um...cooooool
invert360 says: Mar 30, 2008. 7:51 PM
you shoud add this to the steampunk group
Modeo (author) in reply to invert360Aug 22, 2008. 9:46 PM
Thanks, I did, I have been a steampunk most of my life without knowing there is a term for it! :)
jongscx says: Feb 28, 2007. 5:14 PM
OSHA, among others... Now, what current is going through those red and black wires trailing off? I'm hoping it's 12V coming from a wall transformer, because its terminals are awfully well exposed for 110V
Modeo (author) in reply to jongscxMar 3, 2007. 6:39 PM
Yes, it's off of a 12v wall transformer.
Oorspronklikheid says: Jan 6, 2007. 9:38 AM
I love this instructable because I wanted to do something very similar. I wanted to make a centrifugal pump.
Modeo (author) in reply to OorspronklikheidJan 6, 2007. 11:07 AM
Have u got an idea how to make the case? I think that would probably be the hardest part.
Oorspronklikheid in reply to ModeoJan 6, 2007. 11:51 AM
Here is how i think the pump should be made.I have seen such a centrifugal pump.I color coded every thing to make it more clear.The pyramid like casing(marked in light blue) can be obtained from a 2L coke bottle.
Modeo (author) in reply to OorspronklikheidJan 6, 2007. 1:12 PM
I have an idea for you: old dishwashers have a motor that has a water tight seal plus a propeller (or is it impeller) all you would need is the pump case with the inlet outlet. People throw away their dishwashers all the time you could probably do this whole thing for free.
N6OZG says: Jan 5, 2007. 7:26 PM
Wow, just goes to show you what can come out of a box of spare parts. I don't think that OSHA would take a liking to this. Its just the kind of thing that looks like it belongs on your workbench.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
