3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Small-scale benchtop power supply
This is a short instructional for modifying a DC laptop brick to make an adjustable voltage output using the LM317 IC.
For schematics, please google "LM317 datasheet." I will only describe the build process in general terms.
Step 1Mini benchtop power supply
This instructional modifies a laptop DC brick to make a slick, breadboard-friendly power supply for all your low-powered projects.
It contains one thru-put, and two, independently adjustable voltage outputs. The circuit uses an LM317 for each of the adjustable outputs. Best of all, it outputs thru a breadboard power strip!
You will need a multimeter in order to accurately adjust the voltages. But you already have one, don't you? You can see my "pen" multimeter hanging in the back.
12 comments
May 14, 2008. 11:47 PMprettyalex16 says:
i am just new here. could you provide a schematic of the design? thank you.
May 6, 2007. 3:03 PMlarams says:
I don't see how this is an instructable. Don't get me wrong it's a nice idea and a useful one at that but I don't see how this instructed anyone on how to do anything.
Jun 29, 2007. 6:02 PMservant74 says:
A treat for those who asked for a LM317 datasheet data sheet :)
www.fairchildsemi.com/ds/LM%2FLM317.pdf if you can't use/see toe link above.
Jan 8, 2007. 11:12 AMrobonut625 says:
Good idea... I like how small it is. Heatsinks on those regulators would be a good idea though.
Jan 26, 2007. 9:49 PMbinnie says:
you can get away with out them they just use up space. unless your going to draw alot of current you dont really need them if the start getting hot i would go out and buy some though
Jan 7, 2007. 9:42 PMLasVegas says:
A link to the datasheet or schematic would help.
Jan 26, 2007. 5:04 AMbinnie says:
i agree howm i sposed to make it if he dosent even provide pin-pin diagram he better hurry up with it though... and what is a 'power brick' is it just a transformer 110/240 > 12
Jan 7, 2007. 10:06 PMFrenchCrawler says:
I used RCA jacks for my power supply's outputs. They work rather well and are easy to connect/disconnect. I've got more then enough cables to hack if I ever need to use more power jacks :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
80
Author:klee27x
