The brain in this clock is PIC16F84A,The time will be displayed when the 'show' pushbutton is pressed. The digits of the time are displayed in BCD on the four LEDs. Tens of hours is displayed followed by hours, tens of minutes and then minutes.
Remove these ads by
Signing UpStep 1Parts
1.PIC16F84A
2.Crystal 32.768khz(you may find in ordinary clocks)
3.Four leds any color
4. Resistors 4x270 ohm
5. Ceramic cap 2x33 Pf
6. Push Buttons 3 peaces
Regards
but when connected to circuit given by you, ic gets hot and gets destroyed even at 3volts
but i liked your idea and will try to troubleshoot.
this thing made me crazy and even I dont know from where i got to arrange the 3 pics
ive got i just got them arranged some how.
I really want to make this thing
Or send me some pictures to see.macobt@gmail.com
https://rapidshare.com/files/4206999002/Clock_2.hex
What LEDs do I need?
This clock works with PIC16F84 microcontroller,and voltage is 5 volts.
Thanks in advance for evry comment.
When is presed the ''select'' button you can set the time.First are the minutes that hours.
Are the button switches momentary or on/off?
How many picofarads should the load capacitance be for the crystal?
And do you must use 33 picofarads for the ceramic disk capacitors?
The switches are momentary
For crystal you need two disk capacitors of 33,yes you must use these because if you use capacitors with smaller or biger capitance the clock will speed up or speed down with work.
So the ASM and full instructions are available.
http://www.piclist.com/techref/piclist/cheapic/binclock.htm
