Smallest Staircase Door in Minecraft
2,910
20
Published
Introduction: Smallest Staircase Door in Minecraft
This door can be used for hidden bases or storage rooms. It is very fast, and it has a small profile, being two by five blocks and only three high.
Step 1: The Foundation
To start off, clear a space of two blocks by five blocks and three blocks under the stair case that will be modified.
Step 2: The First Layer
The first layer consists of the following blocks: one sticky piston, one dropper, and five blocks of your choice. Add an item of your choice inside of the dropper.
Step 3: Redstone!
Redstone for this step is one repeater set to two ticks, one torch, and three pieces of redstone dust.
Step 4: The Second Layer
One comparator, two piston and one hopper.
Step 5: The Third Layer
Just a few stairs
Step 6: Two More Blocks
Add a block to the back stair, and a half slab next to that block.
Step 7: Put Redstone on It
Add a piece of redstone to the half slab.
Step 8: Power It
Step 9: Finished
Add stairs around the door.
Step 10: Extra Step
This build can be mirrored to make the door two wide.
    • Stick It! Contest
      Stick It! Contest
    • Clocks Contest
      Clocks Contest
    • Game Life Contest
      Game Life Contest
    2 Discussions
    I was just wondering how you are supposed to power the door from the outside. I tried doing red stone where the lever was, but since the rest of the Reston was down below, it didn't work. Also, the stone stairs only go down one block, so I cannot get through, sorry for the trouble.
