loading
Step 2: Frame And Tail
The frame is made out of 75mmX50mm hollow steel, with a angle section welded on one end to act as a rest for the tail and a section of one of the shafts of the smart drive washing machine motor has been welded on a  angle of 30 degrees back and to the side away from the stator to provide the furling for the tail. The bearing mount for the generators is made out of some flat stock  and round stock with a bolt to lock the bearing assembly in. to make this simpler i would do way with the mount that i made and make u-bolts to go over the bearing assembly and lock it down on the frame. the swivel is a piece of the 75mmX50mm box section with a 150mm length of 50mm inside diameter pipe welded on the bottom for the swivel. this is all held on by two u-bolts to allow adjustment for the furling.
The tail is the 200mmX20mm steel pipe welded to a section of pipe with a 30mm inside diameter at a angle of 55 degrees with a gusset for strength, this is the swivel end. The other end has a piece of plywood or sheet metal bolted to it, This needs to be about 700mm square at least.
a wicked idea bro , put to good use. A question to all if i may? an idea popped into Swaxmans brain whilst cutting pvc blades for his WindCoGen. the idea a " ducted fan wind turbine" . basically self explanitory. 360deg of turbine blades shrouded in a cylindrical houseing , normal centre bearing , and shaft coupled to the MagCoGenerator, Blades being ,practical and $$ viable .producing good torque work well, could swaxmans ducted fan design work and be as efficient as three blades?
By thicknesser do you mean a Micrometer?
<p>A thicknesser is a machine that decreases the thickness of timber. google wood thicknesser.</p>
Ahh I know what you mean now.
efficiency will be greatly improved with blades.
Yes efficiency has now been improved with blades!
lol I really hope that was meant as a joke. <br>
What are you using with the coils? in terms of magnetism, you didn't cover that part? <br> <br>Nice design though!
The alternators are off smart drive washing machines. they have the magnetic rotor with them that i leave un-altered so thats why i didn't put it in. the coils are just re-wound to give a lower voltage and higher current.
This looks interesting, but what on earth is the VGA cable there for? and how would you use it?? It looks to me like a small PCB circuit, and I see no micro controller that could produce a GUI...
Its a serial port, not VGA. it is used to program the picaxe micro-controller and to collect the logging data.
I have a lot of UPS units which most of the small ones were srapped, but wonder if you could use the larger systems to convert to 120volts, while using the battery stack to store the wind generated power. I would also like to know if there is a way to increase or modulate the generators to keep blade speed at a managable speed in high wind conditions, or basically, as a brake and thus being able to utilize all power developed, instead of using a mechanical brake to keep blades from over-spin...... <br> <br>I really like this instructable, please update when you get moved and get the unit operating.... <br> <br>Dan
Yep your idea should work well. the speed of the blades are regulated by the self furling tail so it will get to its max output then as the wind speed increases it will furl towards the tail regulating the blades speed.
Having easy access to the head and blades is very important, as bugs are one of the downfalls of blade performance. They will need to be cleaned frequently if you expect to operate at peak performance. <br> <br>Keep up the good work, and any designs that will make this a maintenance friendly system. This has always been a problem with the much bigger commercial units, keeping it clean that is........ I always wondered about some kind of teflon coating for the blades, but even then you would need access to wipe the blades clean. <br> <br>Dan
how do you protect the whirly bits from inclement weather? <br> <br>The bearings and wires were never meant to stay outside in the rain, snow, sun, etc... <br>Or do you just tilt the tower down, and rebuild them when stuff starts to go wonky?
Very good point as i said i didn't get it all quite working before i packed it up before moving house, there is a fiberglass cover that covers all the electronics and things up top.
Well There some sealed bearing /heavy duty that exist, they were made to work outside, with some water displacing grease you would only need to grease them from time to time (Grease line could be fitted look up &quot;Auto-librification system&quot; for idea) <br> <br>As for the wire... there a lots protector type. A good quality one combined with ether &quot;pro-seal&quot; or Deutsch connector could do the trick.
Hey, I like the turbine design, but just a thought to make it more efficient. You could turn the second motor backwards and put a second set of blades going the opposite direction of the first, this would give you more than wife as much efficiency beause each blade would be easier to turn because of less drag from the motors, you would now have two, and the opposite directions is used in high efficiency plane and nuclear turbines. Just a thought, it wiuldn't require any rewiring just a new setup for the alternators.
The problem with that is the second alternator would get turbulence of the first set of blades decreasing its efficiency hugely, your properly better off having them on the same set of blades and making them bigger.
Could you please add a handmade drawing for this?
i was with you until you suggested;Heavy gauge insulated two core wire to run the power from your wind turbine to where you want the power.. Take it from me, When ever your dealing with Any kind of Metal on a High Pole, Always 3 Core electrical Wire, Such as Romen-X Metal shielded Wire, So it can be Easily Grounded. Thus Saving You, Your Family and Your Home from Lightning Strikes and Fire. <br>Also, Always Keep your Storage Batteries separate from your house, Depending on what type of battery you use, Your Battery room can be full of Hydrogen Gas resulting in a very Deadly Explosion. But your Idea looks great, Good Job.
Yeep your right about the earth wire thanks. The batterys are been keep separate they have there own little shed. <br> <br>thanks for your advice
Ciao Ben, <br>very well described, indeed. <br>Have you got any preview or real information about the amount of achieved power w/r to wind conditions? <br>Even early preliminary data would be welcome.... <br>
Beautiful, very simplistic design and a very good one. Thank You for sharing
About This Instructable
91,362views
401favorites
License:
Bio: I'm a student studying engineering at Canterbury University in New Zealand. with a passion for renewable energy, electronics and almost all engineering. I have ... More »
More by benmurton:Minecraft Flying Machines Acrylic Skeleton Clock Improved Rechargable Torch
Add instructable to:
