Smart Greenhouse Sensors
Published
Introduction: Smart Greenhouse Sensors
About: Everyone has been made for some particular work, and the desire for that work has been put in every heart. Rumi
This Instructable is now in Microcontroller contest, please vote for it :D
Hello everyone,
Today I will show you my little project that I built for couple of days.
This set is made of 4 (four) different sensors and I think that every greenhouse owner should have it, and it should make his life a bit easier.
LCD sensors output is in Bosnian, but I will translate it for you in the code and here. :)
Total cost of this project: $16 or €13,5 (does not include tools and you can go cheaper if you salvage some parts).
I will post items that I bought from Aliexpress, and they are the cheapest and best quality ones that you can find on Aliexpress.
ENJOY! :)
Caution:
I am not responsible if you hurt yourself or others around you!
Step 1: Gathering Items and Tools
For this project you will need:
Arduino board (I used "Nano"): https://goo.gl/wBj3nj
LCD I2C screen: https://goo.gl/PHX9F6
Photoresistor for light sensor: https://goo.gl/o1VDUq
Soil moisture sensor: https://goo.gl/F9DRF2
DHT11 temperature and humidity sensor: https://goo.gl/1v9bfk
Mini Solar panel https://goo.gl/c6woCL
3.7V battery (best to use one from an old phone or LiPo because of space) https://goo.gl/YDvYov
TP4056 battery charge/dishcharge protection: https://goo.gl/9bTYqU
Boost buck converter 3.7V to 5V (manually fixed): https://goo.gl/NZsrv7
LEDs: https://goo.gl/9B4aW6
Tactile switch for reset (optional): https://goo.gl/j61LXh
Switch (you can use any, I used these): https://goo.gl/tMKrPk
Heatshrink tubing, duct tape, wire and installation box you can probably buy in your local store.
Step 2: Schematics
I made this detailed schematics for you, I hope that it's not too complicated, but I will write all connections.
If you can't see, I uploaded my .fzz Fritzing schematics or you can download my high resolution schema: https://goo.gl/Fj4tNY
- I2C LCD screen
SDA --- Arduino A4
SCL --- Arduino A5
VCC --- Arduino 5V
GND --- Arduino GND
- DHT11/DHT22 temperature and humidity sensor
From left to right
First pin --- 5V
Second pin --- D4
Third pin --- nothing
Fourth pin --- GND
- Soil moisture sensor
VCC --- Arduino 5V
GND --- Arduino GND
D0 --- nothing
A0 --- Arduino A1
(+ and -) --- probe (polarity doesn't matter)
- 6V 1W solar panel
Positive wire (+) --- TP4056 INPUT (+) (it's next to Micro USB port)
Negative wire (-) --- TP4056 INPUT (-) (same)
- 3.7V rechargable battery (don't make a mistake here)
Positive wire (+) --- TP4056 (B+)
Negative wire (-) --- TP4056 (B-)
- Boost buck converter
(VIN+) --- TP4056 (OUT+)
(VIN-) --- TP4056(OUT-)
(VOUT+) --- Arduino VIN
(VOUT-) --- Arduino GND
-For light sensor please see schematics-
Step 3: Uploading the Code to Arduino
You will need to download some libraries:
DHT sensor library: https://github.com/adafruit/DHT-sensor-library
LCD I2C library: https://github.com/fdebrabander/Arduino-LiquidCrys...
LIGHT SENSOR LIBRARY: http://robotsbigdata.com/assets/downloads/RBD_Ligh...
Copy them to: ...\Arduino\libraries
And upload the code to Arduino.
Step 4: Connecting Everything
Be sure to use short wire and good quality solder.
For the box part, I uploaded a picture which shows you how to connect signal LEDs.
Desolder small SMD LEDs from boost converter and TP4056 module, glue your own LEDs to box and solder them to modules.
Reset button is optional, connect one end of tactile switch to GND and the other to RST pin on Arduino.
Be sure to turn the photoresistor to the sky.
Best box to use is the installation box for the electrical cables. They can withstand high temperatures and will protect electronics in it. (You can use hot glue to glue everything and it will not even get warm in this box)
Measure the LCD screen and cut the installation box to fit the LCD screen. Then glue it tightly with hot glue or epoxy.
Glue the solar panel with syntelan or epoxy (don't use hot glue here because it will melt on sun) on the top and take the cables from it through the box and into the box.
Step 5: Done!
Place it somewhere in your greenhouse. The best place to place it is somewhere in the middle of the greenhouse.
If you look closely at the bottom of wooden pole you can see that I made a coil of wire that is connected to the soil moisture sensor, so I can unwind it and measure the moisture anywhere in the greenhouse.
Translation of video:
Temperatura - temperature
Vlaznost zraka - humidity
Vlaznost tla - Soil moisture
Svjetlost - Light
Feel free to ask any questions.
Have a nice day :D
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
