Smart Home Monitoring Using Edison
Published
Introduction: Smart Home Monitoring Using Edison
For frequent travellers and those who have multiple houses and those who have to switch between them frequently,Smart Home Profile is a Home Automation solution that solves his need to reiterate his personal preferences
Step 1: Managing Sensors Via Python
#!/usr/bin/env python
import mraa,json,urllib,time
sensors=["sensor_a","sensor_b","sensor_c"] sensor_a = mraa.Gpio(6) sensor_b = mraa.Gpio(7) sensor_c = mraa.Gpio(8)
sensor_a.dir(mraa.DIR_OUT) sensor_b.dir(mraa.DIR_OUT) sensor_c.dir(mraa.DIR_OUT)
user="bc-ef-f0-c5"
times=[5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,00,1,2,3,4,]
for value in times: sensor_a.write(int(json.loads((urllib.urlopen('https://bc-ef-f0-c5.firebaseio.com/time/7:00/sensor_'+a+'.json')).read()))) sensor_b.write(int(json.loads((urllib.urlopen('https://bc-ef-f0-c5.firebaseio.com/time/7:00/sensor_'+b+'.json')).read()))) sensor_c.write(int(json.loads((urllib.urlopen('https://bc-ef-f0-c5.firebaseio.com/time/7:00/sensor_'+c+'.json')).read()))) time.sleep(3)
time.sleep(10)
Step 2: Connecting to Cloud
You can use Openshift for cloud based application.I made an Python application based on Flask.
and for database solution I used Firebase
I used MFRC522 for RFID tag for for edison
#include
#include
#define SS_PIN 10 #define RST_PIN 9 MFRC522 rfid(SS_PIN, RST_PIN); // Instance of the class
MFRC522::MIFARE_Key key;
// Init array that will store new NUID byte nuidPICC[3]; SoftwareSerial portOne(10, 11);
void setup() { Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for native USB port only }
// Start each software serial port portOne.begin(9600); SPI.begin(); // Init SPI bus rfid.PCD_Init(); // Init MFRC522
for (byte i = 0; i < 6; i++) { key.keyByte[i] = 0xFF; }
//Serial.println(F("This code scan the MIFARE Classsic NUID.")); //Serial.print(F("Using the following key:")); //printHex(key.keyByte, MFRC522::MF_KEY_SIZE); } void loop() {
// Look for new cards if ( ! rfid.PICC_IsNewCardPresent()) return;
// Verify if the NUID has been readed if ( ! rfid.PICC_ReadCardSerial()) return;
//Serial.print(F("PICC type: ")); MFRC522::PICC_Type piccType = rfid.PICC_GetType(rfid.uid.sak); // Serial.println(rfid.PICC_GetTypeName(piccType));
// Check is the PICC of Classic MIFARE type if (piccType != MFRC522::PICC_TYPE_MIFARE_MINI && piccType != MFRC522::PICC_TYPE_MIFARE_1K && piccType != MFRC522::PICC_TYPE_MIFARE_4K) { //Serial.println(F("Your tag is not of type MIFARE Classic.")); return; }
if (rfid.uid.uidByte[0] != nuidPICC[0] || rfid.uid.uidByte[1] != nuidPICC[1] || rfid.uid.uidByte[2] != nuidPICC[2] || rfid.uid.uidByte[3] != nuidPICC[3] ) { //Serial.println(F("A new card has been detected."));
// Store NUID into nuidPICC array for (byte i = 0; i < 4; i++) { nuidPICC[i] = rfid.uid.uidByte[i]; } Serial.println(F("The NUID tag is:")); //Serial.print(F("In hex: ")); printHex(rfid.uid.uidByte, rfid.uid.size); } else Serial.println(F("Card read previously."));
// Halt PICC rfid.PICC_HaltA();
// Stop encryption on PCD rfid.PCD_StopCrypto1(); }
void printHex(byte *buffer, byte bufferSize) { for (byte i = 0; i < bufferSize; i++) { Serial.print(buffer[i] < 0x10 ? " 0" : " "); Serial.print(buffer[i], HEX); portOne.write(2); //Serial.write(buffer[i] < 0x10 ? " 0" : " "); //Serial.write(buffer[i], HEX); } }
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
