Smart LED With Node Mcu and Tasker
896
Posted in TechnologyArduino
Introduction: Smart LED With Node Mcu and Tasker
About: random robot and maker from belgium
download tasker.
Step 1: The Links
https://play.google.com/store/apps/details?id=net.... -> tasker
https://thinger.io/ -> thinger api
https://www.amazon.de/Eleduino-Version-NodeMCU-Int... - > the nodemcu module
you can use any output you wish in my example i used an rgb led strip
Step 2: Wirering
do this with a breadboard before soldering
Step 3: Setup Node Mcu and Tasker
Firstly open the Arduino IDEGo to files and click on the preference in the Arduino IDE
copy the below code in the Additional boards Managerhttp://arduino.esp8266.com/stable/package_esp8266com_index.jsonclick OK to close the preference Tab.
Step 4: The Right Board
After completing the above steps , go to Tools and board, and then select board Manager
Navigate to esp8266 by esp8266 community and install the software for Arduino.Once all the above process been completed we are read to program our esp8266 with Arduino IDE.
Step 5: Instal the Esp One
Step 6: Chose This Libary and Add This Code
#include < SPI.h>
#include < ESP8266WiFi.h >
#include < ThingerESP8266.h >
#define USERNAME "yourusernamen" #define DEVICE_ID "your device" #define DEVICE_CREDENTIAL "your cridentials"
#define SSID "yourssd"
#define SSID_PASSWORD "wifipass"
ThingerESP8266 thing(USERNAME, DEVICE_ID, DEVICE_CREDENTIAL);
void setup() { pinMode(D5, OUTPUT);
thing.add_wifi(SSID);
// digital pin control example (i.e. turning on/off a light, a relay, configuring a parameter, etc) thing["led"] << digitalPin(D5) ;
// resource output example (i.e. reading a sensor value) thing["millis"] >> outputValue(millis());
// more details at http://docs.thinger.io/arduino/ }
void loop() { thing.handle(); }
Step 7: Do a Http Post in Tasker
tasker uses if and then statements or action reaction
for example if time = 11:00pm then do http post
i used a pluggin called autovoice
NOTE: this plugin is payed.
(it is cheap)
Step 8: Done
Step 9: Final: You Can Always Make a Case I Made Mine With a Laser Cutter and a Simple Interlocking.
if you can't make it yourself use this link: https://makeabox.io/
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    Nice First Instructable. You should enter this into the First Time Authors contest.
