Introduction: Smart Lamp (TCfD) - Rainbow + Music Visualizer
Picture of Smart Lamp (TCfD) - Rainbow + Music Visualizer
This project is done for the course Technology for Concept Design at the TUDelft
The Final product is an ESP-32 base LED lamp and is connected to the server. For the prototype, the lamp has two functions; a rainbow effect that emits a soothing color shifting glow towards its surroundings and secondly sound visualizer where the LED pixels “dance” according to sound levels. The system is connected to wifi and the user is able to choose what effect they want from the lamp via WIFI.
The cheap ESP-32 microchip provides us with powerful processors, inbuilt hall sensor, temperature sensor, touch sensor and also wifi and bluetooth capability. With this, Whilst only two effects were chosen for this project, The implication of this “smart” lamp is limitless. It would be used to indicate the weather to the user, or the temperature of the room, the lamp itself can act as an alarm trigger or it can give a calming sunlight glow next to your bed simulating sunrise for a nice wakeup experience.
Step 1: Material Needed
Arduino esp32
Sound sensor
Four way Bi-Directional Logic Level converter
Neopixel led 2m 60 led/m
Jumper wires
Micro USB cable with adapter
Internet connection
Step 2: Circuit Diagram
Picture of Circuit Diagram
A circuit diagram was drawn and circuit was made accordingly as given in
the diagram below.
Step 3: Arduino Code
Here, firstly visualizer code was made. Then, two example code
;“neoplxel RGBW starndtest”; and “simpleWebServerWifi” was modified and integrated within the visualizer code. Although the code is still buggy at times (random led’s light up time to time). Next iteration of the code (once we get enough time) will be updated.
#include
#ifdef __AVR__
#include
#endif
const int numReadings = 5;
int readings[numReadings];
int readIndex = 0;
int total = 0;
int average = 0;
int micPin = 33;
#define PIN 4
#define NUM_LEDS 120
#define BRIGHTNESS 100
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRBW + NEO_KHZ800);
byte neopix_gamma[] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1,
1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2,
2, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 5, 5, 5,
5, 6, 6, 6, 6, 7, 7, 7, 7, 8, 8, 8, 9, 9, 9, 10,
10, 10, 11, 11, 11, 12, 12, 13, 13, 13, 14, 14, 15, 15, 16, 16,
17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 24, 25,
25, 26, 27, 27, 28, 29, 29, 30, 31, 32, 32, 33, 34, 35, 35, 36,
37, 38, 39, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 50,
51, 52, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 66, 67, 68,
69, 70, 72, 73, 74, 75, 77, 78, 79, 81, 82, 83, 85, 86, 87, 89,
90, 92, 93, 95, 96, 98, 99,101,102,104,105,107,109,110,112,114,
115,117,119,120,122,124,126,127,129,131,133,135,137,138,140,142,
144,146,148,150,152,154,156,158,160,162,164,167,169,171,173,175,
177,180,182,184,186,189,191,193,196,198,200,203,205,208,210,213,
215,218,220,223,225,228,231,233,236,239,241,244,247,249,252,255 };
#include
#include
char ssid[] = "yourNetwork"; // your network SSID (name)
char pass[] = "secretPassword"; // your network password
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
void setup()
Serial.begin(9600); // initialize serial communication
pinMode(9, OUTPUT); // set the LED pin mode
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
while (true); // don't continue
String fv = WiFi.firmwareVersion();
if (fv != "1.1.0") {
Serial.println("Please upgrade the firmware");
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to Network named: ");
Serial.println(ssid); // print the network name (SSID);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
server.begin(); // start the web server on port 80
printWifiStatus(); // you're connected now, so print out the status
Serial.begin(9600);
strip.setBrightness(BRIGHTNESS);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
pinMode(micPin, INPUT);
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
void visualizer(){
total = total - readings[readIndex];
readings[readIndex] = analogRead(micPin);
total = total + readings[readIndex];
readIndex = readIndex + 1;
if (readIndex >= numReadings) {
readIndex = 0;
average = total / numReadings;
delay(1);
int micpixel = (average-100)/5;
Serial.println(micpixel);
if (micpixel > 0){
for(int j=0; j<=micpixel; j++)
strip.setPixelColor(j,(micpixel*2),0,(90-micpixel),0);
for(int j=micpixel; j<=NUM_LEDS; j++)
strip.setPixelColor(j,0,0,0,0);
strip.show();
if (micpixel < 0) {
for(int j=0; j<=20; j++)
strip.setPixelColor(j,0,0,50,0);
strip.show();
void loop() {
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("HTTP/1.1 200 OK");
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("Click here Turn on Rainbow effect
client.print("Click here Turn on Visualizer
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
break;
} else { // if you got a newline, then clear currentLine:
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Check to see if the client request was "GET /H" or "GET /L":
if (currentLine.endsWith("GET /R")) {
Rainbow(10); // Rainbow effect turned on
if (currentLine.endsWith("GET /V")) {
Visualizer(); // Visualizer is turned on
// close the connection:
client.stop();
Serial.println("client disonnected");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3,0);
if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3,0);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0,0);
uint8_t red(uint32_t c) {
return (c >> 16);
uint8_t green(uint32_t c) {
return (c >> 8);
uint8_t blue(uint32_t c) {
return (c);
//Serial.println(micpixel);
Step 4: 3d Printing the Base of the Lamp
Picture of 3d Printing the Base of the Lamp
A 3d model of the lamp base was measured, designed and printed with dimensions big enough to fit all the electric components inside the base compartment.
Step 5: Led Attachment
Picture of Led Attachment
Led’s were winded in cardboard roll and attached using double sided tape, a hole was drilled in the bottom part to pass the wire through
Step 6: Lamp Enclosure
Picture of Lamp Enclosure
An enclosure was made by finding a transparent bottle with similar width as lamp base and height as the LED attachment. This was then covered with thick paper for better diffusion of light. Alternatively, it is possible to use frosted glass or translucent plastic tubes as lamp enclosure.
Step 7: Setup
Picture of Setup
Everything was glued together and assembled. And the lamp was ready for some testing!.
Swansong (author)2017-12-22
I love reactive lamps like this, they're really pretty!
sagarsanket (author)Swansong2017-12-22
Thank you! please pm me if you face any problems when you build them
About This Instructable
999views
19favorites
License:
More by sagarsanket:Smart Lamp (TCfD) - Rainbow + Music Visualizer
Add instructable to:
