Smart Street Light Using Ir Sensor With Arduino
18,199
46
64
Published
Introduction: Smart Street Light Using Ir Sensor With Arduino
About: i am 20 year old electrical engineer from india.
Please SUBSCRIBEto my channel for more projects.
This project is about Smart street light, street light will turn on while vehicle is passing through it.
here we are using 4 IR sensors that senses the position of the vehicle,each IR sensor controls 3 LED's. When vehicle passes by a particular IR sensor it senses the position of vehicle and gives its signal to the arduino board and it will turn on the LED's.
ADVANTAGES:
If we uses this idea and implement to it in our society it will be helpful in saving enough amount of electricity and off-course money.
Step 1: Components Required
  1. arduino uno
  2. ir sensor (4)
  3. 10mm LEDs (6)
  4. connecting wire
  5. foam board
Step 2: Upload the Program
download and upload the program in arduino uno
Step 3: Connect the Circuit
Connect all the components as given in the circuit diagram.
ir sensor 1 ---> 2
ir sensor 2 ---> 3
ir sensor 3 ---> 4
ir sensor 4 ---> 5
connect all ir sensor's to +5v and ground.
the positive pin of leds are connected to these pins of arduino.
led 1 ------> 6
led 2 ------> 7
led 3 ------> 8
led 4 ------> 9
led 5 ------> 10
led 6 ------> 11
and finally all ground pins of led connect to the ground of arduino.
Step 4: Build Suitable Structure
To make these poles as given in above picture, use foam board and glue.
and you may also use black chart to make a road and wooden board for the base of pole.
  • Make it Move Contest
  • Microcontroller Contest
  • Woodworking Contest
    Woodworking Contest
5 Tips
the correct code is scroll down see in comments (omtaphM) comment
hi
,I have finished my sisters project today finally I m from Andhra I used many youtubes videos but I cant do it and I came to these site I have done THANK YOU VERY MUCH (VISHALONINDIA)
YOU CAN ASK ANY QUESTION Samuelphilip2003@gmail.com
THE CORRECT CODE IS::::
Anyone,s whose project is working opposite(i.e. led's are turning off when an object is coming close to the IR sensor), Please use my codes it will work perfectly ,
int ir1=2;
int ir2=3;
int ir3=4;
int ir4=5;
int led1=6;
int led2=7;
int led3=8;
int led4=9;
int led5=10;
int led6=11;
int proxy1=0;
int proxy2=0;
int proxy3=0;
int proxy4=0;
void setup()
pinMode(ir1,INPUT);
pinMode(ir2,INPUT);
pinMode(ir3,INPUT);
pinMode(ir4,INPUT);
pinMode(led1,OUTPUT);
pinMode(led2,OUTPUT);
pinMode(led3,OUTPUT);
pinMode(led4,OUTPUT);
pinMode(led5,OUTPUT);
pinMode(led6,OUTPUT);
void loop(){
proxy1=digitalRead(ir1);
proxy2=digitalRead(ir2);
proxy3=digitalRead(ir3);
proxy4=digitalRead(ir4);
if(proxy1==HIGH)
digitalWrite(led1,LOW);
digitalWrite(led2,LOW);
digitalWrite(led3,LOW);
else
digitalWrite(led1,HIGH);
digitalWrite(led2,HIGH);
digitalWrite(led3,HIGH);
if(proxy2==HIGH)
digitalWrite(led4,LOW);
else
digitalWrite(led4,HIGH);
if(proxy3==HIGH)
digitalWrite(led5,LOW);
else
digitalWrite(led5,HIGH);
if(proxy4==HIGH)
digitalWrite(led6,LOW);
else
digitalWrite(led6,HIGH);
5v to 5v and gnd to gnd?????
15 Questions
Sir,
Can you please send me the circuit diagram and program for the same project using LDR
so that the LEDs doesnt glow in the morning.
Hello sir, I need a help, I need a code for the situation like at a time two vehicles are on the same Street on opposite sides...
Sir im having a problem! The led is on all the time and when something is in fromt of the ir sensor the led switches off! What should i do
use this code
int ir1=2;
int ir2=3;
int ir3=4;
int ir4=5;
int led1=6;
int led2=7;
int led3=8;
int led4=9;
int led5=10;
int led6=11;
int proxy1=0;
int proxy2=0;
int proxy3=0;
int proxy4=0;
void setup()
pinMode(ir1,INPUT);
pinMode(ir2,INPUT);
pinMode(ir3,INPUT);
pinMode(ir4,INPUT);
void loop(){
if(proxy1==HIGH)
else
if(proxy2==HIGH)
else
if(proxy3==HIGH)
else
if(proxy4==HIGH)
else
The circuit not working
Pls send me the detail for connecting ir transmitter and receiver connection and the amnt of resistance is to be connect and any separate circuit for IR trsmtr and IR photo diode
I have bought ready made ir circuit
Sir,
Can you please send us the circuit diagram and program for the same project using LDR
so that the led doesnt glow in the morning
You have to do your self... I am no longer working on this
Both negative of ir's is to be Ground right? And positive of ir transmitter is connect to 5v and positive trmnl of IR receiver is connect to Port 2,3,4 &5 right
And for led negative is connect to the grnd and positive is to be cannect to port,6,7,8,9,10 &11 right?
Where to connect the Gnd n +5v of sensor to arduino????
Arduino has 5v and ground pin
hello can you make the circuit more clear please .
Sorry for asking.But why did you used only 6 leds when 1 IR can control 3 leds?why did't u used 12 leds for all the IR's?And what should i change if i want to use 12 leds for all 4 IR's?Tanx in advance.
Yes Connect at as circuit...... And remain open that you not require
HI! I AM MAKING THIS PROJECT BUT I AM GETTING SOME TROUBLE WHILE UPLODING CODES. WHILE UPLODING CODES THIS MESSAGE IS SHOWING SOME MESSAGE AND I HAVE ADDED ONE IMAGE KINDLY CHECK THIS UP. FOR CONTACT ME KINDLY INFORM ME AT kakadiapramey12@gmail.com
One curly breaches are missing...... Again download the program
This codes aren't working??? Please help me with it
The program is in which language?
64 Comments
Is there a need of interfacing between PIR sensor and arduino
I need some help sir.
You have given the pin configuration and conenctiom for only led and ir sensors! Can you please gove the circuit diagram from the input terminal and all other terminals used please! Like if there is a resistance or where is the input power given and so on! It would be of great help sir
int ir1=2;
int ir2=3;
int ir3=4;
int ir4=5;
int led1=6;
int led2=7;
int led3=8;
int led4=9;
int led5=10;
int led6=11;
int proxy1=0;
int proxy2=0;
int proxy3=0;
int proxy4=0;
void setup()
pinMode(ir1,INPUT);
pinMode(ir2,INPUT);
pinMode(ir3,INPUT);
pinMode(ir4,INPUT);
void loop(){
if(proxy1==HIGH)
else
if(proxy2==HIGH)
else
if(proxy3==HIGH)
else
if(proxy4==HIGH)
else
Thanks for the project with detailed instructions, but I think your code is wrong, the leds are working opposite to what it should do, I made some changes to the codes and i am providing my code below for those who are facing the same issue.
USE IT , 100% WORKING
int ir1=2;
int ir2=3;
int ir3=4;
int ir4=5;
int led1=6;
int led2=7;
int led3=8;
int led4=9;
int led5=10;
int led6=11;
int proxy1=0;
int proxy2=0;
int proxy3=0;
int proxy4=0;
void setup()
pinMode(ir1,INPUT);
pinMode(ir2,INPUT);
pinMode(ir3,INPUT);
pinMode(ir4,INPUT);
void loop(){
if(proxy1==HIGH)
else
if(proxy2==HIGH)
else
if(proxy3==HIGH)
else
if(proxy4==HIGH)
else
Hi
We are also make ir sensor project...
It is nice project and electricity saver project that is help in future,but one problem the led port was not connected properly so please send wireing of the project..Fast..
Please Give me the details of IR sensor (model no, etc) and where to buy it ??
Ir sensor is same everywhere......
Just buy it sensor as shown in picture or search it on online website
Sir jab din me vehicle movement hogi to kia tab b lights on ho jayen gi kia?
Han..... Ho jayegi...
Din m band krne k liye ldr lagana padega
Hi. please i have code about ir sensor interrupt which use for know traffic state and control with light signal .Excuse Compulsively
If you have have code then what can I do for you
nothing .also i face problem in write interrupt ir sensor interrupt code..can you help me in my proect??expline its
excuse me for bothering but I want interrupt code and don't know how write it ...because my program contain alot of commends....could you write interrupt?and in your code not contain ir library is not it? ?
i dont know how write interrupt and this is i want from you and ir library ...i want interrupt for ir sensor to know density state and deal it...can you help me ?.
