Introduction: Smart Trash Bin - Email Notifier When Full (Wifi IoT)
This is a smart trash bin that senses if the trash is full and sends a notification to you to let you know its time to empty it!
Step 1: BoM
* ESP32
* Ultrasonic Sensor - HC-SR04
* Female-Female Jumper Cable
* Trash bin
Tools:
Hot Glue Gun
Step 2: Wiring
* Connect the VCC pin on the Ultrasonic sensor to 3.3V on the ESP32
* Connect the GND pin on the Ultrasonic sensor to the GND pin on the ESP32
* Connect the Trig Pin on the Ultrasonic sensor to D4 on the ESP32
* Connect the Echo Pin on the Ultrasonic sensor to D5 on the ESP32
Step 3: Mount
Glue the ultrasonic sensor such that it is facing downward towards the trash bin.
Step 4: Upload Code to ESP32
#define BLYNK_PRINT Serial
/* Set this to a bigger number, to enable sending longer messages */ //#define BLYNK_MAX_SENDBYTES 128
#include "WiFi.h"
#include "WiFiClient.h" #include "BlynkSimpleEsp32.h"
// You should get Auth Token in the Blynk App. // Go to the Project Settings (nut icon). char auth[] = "YourAuthToken";
// Your WiFi credentials. // Set password to "" for open networks. char ssid[] = "YourNetworkName"; char pass[] = "YourPassword";
void emailOnButtonPress() { // *** WARNING: You are limited to send ONLY ONE E-MAIL PER 15 SECONDS! ***
// Let's send an e-mail when you press the button // connected to digital pin 2 on your Arduino
digitalWrite(trigPin, LOW); delayMicroseconds(2); // Sets the trigPin on HIGH state for 10 micro seconds digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW); // Reads the echoPin, returns the sound wave travel time in microseconds float duration = pulseIn(echoPin, HIGH); // Calculating the distance distance= duration*0.034/2; if (distance<2) { Blynk.email("techmartian@techmartian.com", "Clean your Trash!");
void setup() { // Debug console Serial.begin(9600);
Blynk.begin(auth, ssid, pass); // You can also specify server: //Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8442);
void loop() { Blynk.run(); }
Step 5: Plug in and Enjoy!
Plug it in to an outlet and enjoy a clean trash bin!
Automation Contest 2017
Makerspace Contest 2017
