Remove these ads by
Signing UpStep 1
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
I looked (googled) pretty much on the subject, and did not find any warnings, in fact I turned up some "wallets" for the Blackberry that have a strong magnetic latch on them.
GPS is electronic not magnetic, I believe, but the compass... do you have to hold it flat for the compass? Perhaps it is electronic too.
I was not able to test it with every type of phone.
As my grandpa used to say: "When in doubt, throw it out" So perhaps this hack is not such a good idea given the phone you have.
Thank you for the comment.
I just wondered if you knew if magnets could cause any lasting effects.
thanks anyhow.
Thank you for checking in again.
Thank you for a great question!
I looked around the net and found some discussion of this :
Magnets affect magnetic media. most cellphones do not have magnetic data media in them, just SD cards which are electric, most modern storage devices, such as SD and CompactFlash memory cards, are immune to magnetic fields. "There's nothing magnetic in flash memory, so [a magnet] won't do anything," says Bill Frank, executive director of the CompactFlash Association. "A magnet powerful enough to disturb the electrons in flash would be powerful enough to suck the iron out of your blood cells," says Frank.
That magnets damage computer chips is generally a myth. For proof, dissect a hard drive. Inside are two of the largest magnets generally found in residential homes.
Putting a piece of metal close to the phone's antenna is never a good idea since it affects the reception and may force the phone to transmit with higher power to maintain a connection with the base station.
But there is no long term damage to the phone (except, perhaps quicker draining of the battery.) As soon as the metal piece is removed from the phone's vicinity, the phone will be back to working normally.
The only magnetic thing in a cell phone is the speaker, though I moved a strong magnet around the back of my 2 iPod Touch's and a iPad, I was not able to affect the speaker sound, plus I usually use headphones, or Bluetooth.
