Smoke & Fume Absorber
7,829
18
Published
Introduction: Smoke & Fume Absorber
A Long History
The ancient Egyptians produced lead and other important metals like gold and silver as early as 5000 BC. In the Roman era, lead was used for coinage, jewelry and other everyday items including the production of Lead pipes for the transportation of water. Remarkably, many of these water systems have been found virtually intact by modern day archeologists’. One important property of lead is its reluctance to breakdown over time. And as we will see later, that is also part of the problem.
Lead has many properties that make it attractive to countless industries, especially electronics. Lead is malleable; it has a low melting point, good electrical and thermal conductivity and is available in large quantities with a relatively low cost. As a common metal Lead has a mass density only rivaled by Gold. Lead is Heavy!
Lead's widespread use in the electronics industry has been well documented as a shielding material for X-rays, RF and Audio, as well as a sound insulator in professional studio applications. Lead/acid batteries power our cars, and lead based solder compounds help form tight durable electrical connections.
The Hazards
Scientific data now shows the cumulative effect that Lead has on the bodies’ central nervous system and the formation of red blood cells. We also know that children are especially vulnerable to high toxicity levels and less likely to tolerate abuse. But although today the problems with Lead are no longer in doubt, clearly the questions about Lead's affect on the environment and on those who come in contact with it, have been around nearly as long as Lead itself.
Remarkably as far back as the 1st century BC some Roman engineers suggested using clay instead of Lead pipes for water systems. This opinion was not based on a long-term government sponsored study, rather the engineers noticed that many lead workers (Plumbers) were getting sick and lacked vigor. They concluded quite rightly, that if the Plumbers were suffering from exposure to lead, others who came in contact with it would probably get sick as well! In spite of these revelations and other more recent warning signs Lead was continually used in many industries until recent times.
Great strides have been made in the health and safety field in the last few decades. As a result, a total ban on the use of Lead additives in paint and gasoline took effect in the 1970’s and ‘80s, and according to current Federal Law, Lead may no longer be used in or around drinking water or in the food industry. The effects of reducing lead pollution in the atmosphere and the water supply are beginning to pay off in the form of a cleaner environment.
In electronics manufacturing however, lead has continued to be used and will be around for some time to come. Lead of course, is one of the major components in solder. Many in the electronic industry have lobbied for exemptions to the banning of lead based solder products on various grounds and as of yet manufacturers have managed to stave off government regulation. Currently, electronics industry associations have begun to implement voluntary bans on the use of Lead with the goal of total elimination in the near future.
While the amount of Lead found in the circuitry of your average VCR or home stereo would at first thought appear to be insignificant, think about how many of these products get tossed away every year! All this stuff ends up in someone’s “back yard”, there to remain forever, like the Roman water pipes of old! Recycling used electronic gear to extract small amounts of Lead is extremely expensive. So, far better to eliminate the problem at the source by reducing or eliminating Lead during manufacture.
Most at Risk
As Technicians, most of our exposure to Lead comes when we repair or build equipment using Lead based solder. Sadly, even if there was an outright ban on any further use of lead solder in the electronics industry, many potential problems would remain whenever we repair older equipment that still has Lead solder forming the joints. In addition to all this, significant health problems can arise from simply breathing in the solder smoke. So, lets take a closer look at how solder is actually used in the electronic industry.
Soldering is the act of joining two metallic surfaces by the use of low melting point metal alloys. Modern electronic Solder is not made entirely of Lead but rather a mixture of elements. Because pure Lead has poor mechanical strength Tin is added to Lead to make the solder connection stronger. In addition, the Tin / Lead mixture has a lower melting point than using Lead alone, a prime consideration in electronics. 60/40 solder contains 60% Tin and 40% Lead.
To promote uniform solder flow (wetting), and also for joint cleaning, a Flux material is added to the 60/40 mix. The smoke that is released when solder is melted comes from heating the flux. For electronics a non-corrosive Rosin-resin flux is used. Although Rosin is a "natural" product made from pine trees (pine tar) its use along with other chemicals added to the flux make the solder fumes naturally acidic and potentially harmful to man. Even naturally produced products can be harmful!
The Smell of Smoke
The residual lead content found in solder smoke is negligible and the most immediate concern with solder smoke comes from breathing the flux fumes. For many people prolonged exposure to solder smoke and fumes may cause headaches, nausea, eye irritation or occasional coughing. For an unlucky few, chronic bronchitis and occupational asthma can be the outcome. It’s estimated that approximately one out of five unprotected industry workers will suffer this fate. While removing Lead from solder is a long-term plus for your body and the environment, protecting users from breathing in solder fumes will yield an immediate benefit in the form of a healthier workspace. Simply put, you are being exposed to the chemicals found in the solder flux every time you smell the smoke.
Another Warning
Perhaps in some ways we have become desensitized to the vast number of warnings, which exist for all of the products we use on a daily basis. Common sense generally prioritizes these hazards into some likelihood of immediate danger or concern. While this attitude is probably human nature it may lull one into a false sense of security. An equal cause for concern should be reserved for the health problems generated by the small, seemingly insignificant abuses, which become cumulative over long periods of time. In many ways these problems are the easiest to control.
As with cigarette smoking, the effects of breathing in solder smoke and working around lead based solder may not become apparent for many years. So the fundamental question then is “How much direct contact with lead and smoke inhalation is too much?” Not being a doctor or a scientist I will personally err on the side of caution. Common sense suggests that if you have the ability to control your exposure to a hazardous material why not do it?
After handling lead based solder, simple washing of hands prior to continuing work or eating will help protect the user from most of the hazards associated with touching the Lead product. Thinking back, I’m sure neither my brother or I, ever washed our hands voluntarily for any reason, let alone after playing with lead soldiers. For the utmost protection against airborne contaminants while soldering, you might choose to control your breathing environment by the use a full-face respirator designed to trap these hazards. While wearing a respirator may offer the worker an improved level of protection, it seems impractical at best. Besides, a respirator only protects the wearer. It does not protect the guests who visit your shop or work area. Enter another partial solution.
Solution
A fume extractor uses fan to remove the smoke, and noxious fumes, created from soldering. The average price of a small hobby version is about 1500 INR, but this one made from the old computer fan, this will run you more like 150 INR. This mini fume extractor won’t be as effective as a larger one, but it’s definitely better than nothing, and extremely portable. Remember, always work in a well-ventilated area.
This is a fast and simple way to avoid solder fume. this is a minimum system but better then nothing.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    3 Comments
    What kind of soldering iron is that? I think that type of tip would be super useful for some of my needs.
    We'd call that a smoke BENDER round these parts.
    Since there is really no absorption or filtering even.
    Still handy to have laying around. keeps the smoke out of your face.
    and by blowing the smoke away from you, it has a better chance to dilute with the room air, to minimize your personal intake.
    As my father is fond of saying
    "The solution to pollution is dilution"
    On the other hand, you can mae a "box" out of green scotch brite pads, fill it with activated charcoal(britta filters, aquarium supply store, amazon?) and strap it in place of the heatsink. now you have SOME absorption, and LOTS of filtration.
    Works pretty good as a smoke eater. If it's ok at getting the stuff out of your water, should make SOME difference in the air passing through.
    yes, this is great,
    surely i will do this..
    thanks..
