Making your own popsicles is easy-peasy. It's also a fun way to fool yourself you're eating dessert when it's really just healthy stuff like yogurt, fruit and the like. Gotcha, taste buds!
Try making these Smoothie Pops from your favorite smoothie recipe (mine follows.)
Remove these ads by
Signing UpStep 1Gather Supplies
Popsicle molds--we have these ones from Tovolo
Fruit, yogurt, and/or juice of your choosing
Flax oil, spirulina, or healthy smoothie-type additives of your choosing
Food processor or blender
Paring Knife
BTW, this pre-chill ideaI got from watching a show called "How It's Made" Fascinating process. Simple but elegant!
Here are the ULTIMATE Instructables on popsicle making! :D
HOW IT'S MADE FROZEN TREAT YOUTUBE EPISODE
(starts at 5:45)
Continues here:
HOW IT'S MADE FROZEN TREAT YOUTUBE EPISODE PART 2
I've been trying to make regular popsicles using Kool-aid, but
I find it tends to separate, i.e. water and flavor, and I get basically
an icecube wrapped around the flavor core.
Does anything like that happen with these recipes?
If not, I think I'll go with the yogurt etc. and forget about the Kool-aid.
cheers,
Buskieboy
Use some clear Karo syrup to lower the freezing point, this will keep them from turning into flavored ice cubes.
Mix up a batch of Kool Aid sorbet in a large bowl and place in the freezer. Periodically stir the mixture with a spoon. Start with water as cold as you can get the mix and sugar to dissolve in. Consider making a simple syrup with the Kool Aid, allowing that to cool and chilling thoroughly ( ice cubes can be added since its all going there anyway ) then adding this liquid to a larger quantity of pre-chilled water.
Once it begins to freeze into slush pour into popsicle molds and allow to fully solidify. The thicker the slush the creamier the final popsicle will be.
Experiment with the Karo syrup and sugar in the Kool Aid ( use real Kool Aid, not the pre-sweetened kind ). If you try this please consider making an instructable.
Use the blender to puree most of the strawberries. Use this in the base smoothy mix. As above pour the blend into a large bowl and place in freezer. Stir periodically as it begins to form a slush.
Once the frozen mixture begins to solidify dice up the remaining berries, either by hand or in a blender to get "nibbles" of berry. Mix these thoroughly into the slush and pour into the popsicle molds.
In most cases the slushie mix will insulate the berry bits enough to keep them soft and edible.
