SUPPLIES
-About 4-5 feet of PVC pipe
-Thick nylon rope
HOW IT WORKS
Apparently because this device does not give off any heat, the snake can't detect it. Thus the brave soul can move it over a raised snake head.
As you pull the rope the noose tightens, pulling the snake toward the end of the pole, tightening the noose. Then it's up to you what happens with the snake!
This very Snake Catcher you see here caught a big rattlesnake recently.
(Cojones not included.)
Remove these ads by
Signing UpStep 1Make Noose
2) Make a classic slip knot (sorry I can't instruct you but it's easy and well documented elsewhere).
Test that the knot works: When you pull the rope from the other end, the noose should tighten.
ALTERNATE WAY: My esteemed fellow Instructablers have a good suggestion to double the rope so you can loosen the loop to let the snake go.
As long as your rope is stiff and thick enough to make it easy to push through the pipe, that makes good sense! Thanks all.
mostly ( about 10 times a year) it are ratsnakes or cobras.I have two babys (3 and 4 years) who like to grab nice shiny things.My house is walled by 3m high walls ,so scared snakes dont leave but hide untill the next encounter.So when i catch a snake ,i kill it ,whatever it is ,i dont take chances . If it slips over the wall ,it lands in the nabours garden and they also have kids ,so all the nabours now what to do is best!
The ONLY change I would make, would be to cap both ends of the pipe, drill a hole through the side at one end, drill a hole in both caps, feed the rope thru the hole in the side, out through the cap closest to the hole in the side, then run the rope down through the inside of the pipe & out through the cap at the back end. I have made many poles for friends like this & never had a problem with them.
The reason for capping the ends, is because 1 time I had a snake crawl inside the pipe & had a heck of a time getting him out as he was wrapped around the rope that was inside the pipe.
capping both ends stops this from happening.
As I said earlier, very good instructable, well written. You did good. :-)
I saw someone using one just like it on this snake blog: http://www.aaanimalcontrol.com/blog/snakeblog.html
Anyway, good work, thanks.
