Snake Hook From a Broken Golf Shaft and Paint Roller
Published
Introduction: Snake Hook From a Broken Golf Shaft and Paint Roller
About: Software Engineer by profession, Biker by passion, DIY tinker by intrest,
This is a snake hook made from a broken Golf shaft and a roller paint brush.
Step 1: Prepping the Shaft
The broken shaft is sanded, cleaned and given multiple green paint coats, followed with 2 coats of clear.
Since the hook is also used in rain, these paint coats prevent the rust and ofcourse gives the eco friendly color quotient.
Step 2: Preparing the Hook
The roller brush is used to make the hook
The brush and handle are stripped off.
For easier pick up of snakes, the hook end is grinded to a slightly tapered/sharpened end. This helps in digging into mud underneath the snake or for scraping on a hard ground.
The hook is neither welded or glued into the shaft.
Pros of welding / glue:
  • Simple design
Cons with welding the hook to shaft:
  • Difficult to carry while travelling.
  • calls for suspicious looks.
  • No possibility of changing to a different shape/sized hook for smaller sized snakes
Cons with Glue:
  • Along with all the downsides of welding, also it Wouldn't have the strength to turn over logs/big stones while herping in forests
Solution:
A small dia metal is tapped with thread and the unthreaded end is welded to the hook.
A counter thread is tapped into the shaft inner side.
Due to long thread, this is very strong and sturdy and at the same time gives the flexibility of interchanging the hooks.
Also with avoiding weird looks it also serves as a hiking stick when the hook is unscrewed.
Finally the green paint job completes the project.
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    That's a neat way to make one!
