Snowblossom Hat Tutorial
 by madebyrae
Contest WinnerFeatured
This tutorial shows you how to make the custom-sized fleece hat (featured in this post on Made By Rae: http://www.made-by-rae.com/2010/11/blossom-baby/) for any size head (adult, baby, or child). The tutorial shows you how to make the hat with flowers but you could easily modify it for a more gender-neutral hat. It can also be reversed if the top of the hat is undone!
All text and photos are the intellectual property of Rae Hoekstra of http://made-by-rae.com; you may link to this tutorial as long as you give proper credit, but please do not copy content for distribution or use on your own website.  Thanks!
Step 1: Measure Head Circumference and Cut out fabric
Take a tape measure and measure in inches the head for which this hat will be fashioned.
Cut two rectangles out of two different colors of fleece as follows: the width of each rectangle should be the head circumference plus 1″ (for seam allowances) divided by 2.  The height of the rectangle should be the width plus 3″ (see picture). Before cutting, make sure that you orient your fabric so that it will stretch more when you pull across the width of the rectangle than when you pull across the length.
Penolopy Bulnick says: Jan 30, 2012. 9:58 AM
I love really soft hats! So cute!
jessyratfink says: Jan 30, 2012. 7:50 AM
That is adorable. I know a toddler this would look just perfect on. :D
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
