Step 1: Measure Head Circumference and Cut out fabric
Take a tape measure and measure in inches the head for which this hat will be fashioned.â¨â¨ Cut two rectangles out of two different colors of flee...
The extra 3″ you added to the height of the hat was for an earflap. Starting 3″ from the bottom edge on one of the long sides, cut across the hat, cur...
With the right sides facing each other, sew the two matching pieces together just along their straight sides (leave the top open) with 1/4″ seams. Th...
With the right sides facing eachother, sew the inside and outside of the hat together along the bottom (curved) edge. Make sure that the center seams...
I find that fleece is stretchy enough that I don’t really need to clip the curved seams before I turn it right-side out, but if you find that the seam...
Cut a few flowers from 2″ squares of fleece. If you wanted a different look you could also cut polka dots or cars or mushrooms or whatever, or just le...
Cut a 1″ strip of fleece and use it to tie the top about 3″ from the top. It may help to try the hat on and see where the best place to tie it will b...
To get the flower-like top you’ll need to cut each color at the top of the hat into about 8 sections. Take the scissors and starting from the top of t...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
