Introduction: Soap Carving for Casting
Picture of Soap Carving for Casting
How to carve a bar of soap into a smaller soap shape. Discussion of various tools that can be used for this purpose. A little silliness - the carving I made is a kind of slug thing - I'm going to cast it in plastic and glue one googly eye to the upturning end. See the flat part?
Step 1: Outline the Basic Shape
Picture of Outline the Basic Shape
Draw a side elevation of the shape you'll carve on the side of the soap. Starting with 2-D on one side of the block is a good way to start thinking in 3-D.
Step 2: Carve Out the Basic Shape
Picture of Carve Out the Basic Shape
I started doing this carving with a Dremel tool, but quickly found that a knife worked much better for the coarse work. Ivory soap at least is quite soft and carves easily. I tried a cutting blade and a grinding disk. The grinding disk is more effective than the cutting blade but both are slower than knife.
Step 3: Do the Fine Carving
Picture of Do the Fine Carving
For smoothing out the edges, the Dremel works better than a knife, especially a serrated one. Try several different grinding bits depending on the shape you're working with.
Step 4: It's Soap, Wash It.
Picture of It's Soap, Wash It.
For a final smoothing, soap as a medium has this great advantage that it dissolves in water. I didn't want to put it under the tap at first, but really, soap doesn't go away all at once. You do have to rub at it. A wet finger isn't enough - dunk that baby.
I could have gotten this smoother if I'd put more effort into it, but I decided it was Fine. SO my slug will be a bit lumpy... that's OK.
BubbleDragon (author)2007-01-24
I love this idea. Please please add your casting instructable - I'm dying to know how you do it!
rachel (author)BubbleDragon2007-01-26
I keep saying this... i really will write the casting one, I just need time! Poke me about it again if you think of it.
mg0930mg (author)rachel2009-07-15
*Poke!*
zachninme (author)rachel2007-08-24
*Poke* Do it when you're not sleeping ;-)
rachel (author)zachninme2007-08-24
Ha! excellent idea. I'm going to add it to my Not Sleeping list now.
(for those of you who are Confused, see here)
Kaiven (author)rachel2009-01-31
*poke* Cmon! How do you cast it?
uniquesoaps (author)2007-12-22
i like it!! if you want to see something nice come see my site http://uniquesoaps.webs.com/
dremmel (author)2006-12-04
horray 4 dremels!!!
gigman (author)2006-10-19
I would think that the heat of melted plastic would melt the soap. Is this a different kind of soap or am I wrong?
rachel (author)gigman2006-11-15
Sorry I just noticed this question! The plastic isn't melted, actually. It's made like epoxy, from two liquid components, which react chemically to create the finished plastic. There is heat involved in the reaction, but not more than (I'm guessing) about 100F. This will be clearer when I do the casting Instructable, I'm hoping to get to that this weekend as I've done enough work with this now that I am starting to get castings that actually look like the model!
mrmath (author)2006-10-19
Please don't forget to do an instructable on the casting!
rotor (author)mrmath2006-10-19
yeah!
Murf (author)mrmath2006-10-19
I agree
About This Instructable
18,156views
23favorites
License:
Bio: I run Neal's CNC in Hayward, CA, an expert CNC cutting and fabrication service. Check out what we do at http://www.nealscnc.com ... More »
More by rachel:Bench-Go-RoundFix a Rusted SculptureDistressed Metal Commemorative Plaque
Add instructable to:
