Socially Confused Clock
I was trying to make something not totally steampunk, but "gear inspired", so I decided to take apart a cheap alarm clock, and make it look different. I also wanted everything to move. I realized that I could make the hours move around the clock, instead of the hour hand pointing to them. And so it was done. I also enjoy weird timepieces. Ones that you have to decode in order to read. This one is fairly simple to read, but is different than the regular clock.
This is a simple project that can easily be done in the course of watching a movie, aka, not too much thought.
Step 1Objects to gather.
Objects to gather.
- Old-Skool Windup Alarm Clock
- Paint (black and red is what I used, you can use whatever you like)
- Craft Knife
- Glue (hot, elmers, and super will all work)
- Basic tools (pliers usually get the job done)
- Packaging Tape
- Scissors
- Pen
- Coathanger (for a stand)
33 comments
Oct 12, 2010. 4:00 PMpoptart9 says:
to make a clock run "backwards", why not just flip the mechanism over. from behind a clock is running backwards....
Jun 8, 2009. 12:44 PMgolddigger1559 says:
you have a binary watch dont you
May 20, 2009. 3:14 PMGoodhart says:
Now, if you could only get it to RUN backwards..... :-) Otherwise it is still a nice little project.
May 25, 2009. 1:38 PMjongscx says:
http://backwardstime-moddy.blogspot.com/
pretty easy, just don't lose the gears.
May 22, 2009. 9:57 AM$ NAB $ says:
I always tried to make a backward moving clock. Somebody must make an instructable on this.
May 24, 2010. 6:14 PMGordieGii says:
You could buy a barber clock (http://www.leevalley.com/US/wood/page.aspx?p=32911&cat=1,42405,42406) and mod the face so the numbers are the right way around.
May 25, 2010. 10:11 AMGoodhart says:
great idea !   or in the spirit of instructables, look inside so one could replicate the movement :-)
Dec 18, 2009. 6:21 AMCybergothiChe says:
 I did , and so did Glitchmaker :)
May 22, 2009. 4:55 PMGoodhart says:
You can actually buy one from a novelty shop that runs backwards....
May 22, 2009. 3:35 PMOwlbear says:
to make a backwards clock use anold,cheap, electric clock and wire it backwards. most clocks that old dont keep time well since they don't convert from 110v to 120v so its no big loss if it doesn't work
May 24, 2009. 7:50 AM$ NAB $ says:
I did tried that but it didn't turn out to be good.
May 23, 2009. 12:38 AMthe_mad_man says:
why are we changing clockwise? I'm confused enough in life as it is.
May 24, 2009. 10:26 PMalextippins says:
there are currently two different instructables on the subject although havent gotten a chance to try this it seems pretty simple and straight forward
http://www.instructables.com/id/Reverse_Clock_1/
Dec 18, 2009. 6:20 AMCybergothiChe says:
 I would highly recommend it :P
May 24, 2009. 1:54 PMdagenius says:
because since the gear is attached to where the hour hand should be, the gear will run clockwise, thus the numbers must be numbered backwards.
May 24, 2009. 7:49 AMGoodhart says:
Since the numbers are backwards, the clock would be more readable again, but it would still be a bit crazy. :-) Plus it is a challenge ;-)
May 20, 2009. 7:04 PMWesley666 says:
I have looked at some cheap clocks and they have a coil that gets pulsed by a little circuit board (if it is not mechanical) that turns the first gear that turns the rest. My question is would you be able to cut the to coil leads and just switch them and it would go backwards?
May 21, 2009. 5:28 AMhiroe says:
no it wouldn't. if it uses I coil that means it uses electromagnets, electromegnets work the same way no matter the polarity. if there's 2 electromagnets then the order they pulse could reverse them but with just one, not so much.
May 21, 2009. 5:47 AMWesley666 says:
Ok thx. I wasn't sure it was just a thought.
May 20, 2009. 11:53 PMtanmanknex says:
it might... the only way to find out is to try!!! and have fun while you're at it!!!
May 20, 2009. 11:54 PMtanmanknex says:
here's a link to another instructable.http://www.instructables.com/id/Reverse_Clock_1/
May 20, 2009. 11:53 PMomnibot says:
Nope, wouldn't work. Reason being that the coil works as an electromagnet and the part attracted by it is not magnetized so reversing the field changes nothing, also the gears and so on will not turn backwards. There is an instructable for a reverse clock mod somewhere which solves this elegantly, suggest that one but am to lazy to link.
May 20, 2009. 5:29 PMmicroman171 says:
I was just thinking that
May 24, 2009. 1:52 PMdagenius says:
how does the minute hand turn?
May 21, 2009. 4:06 AMfinfan7 says:
Not a bad gearpunk creation seems in need of a little sanding though.
May 20, 2009. 4:40 PMcowscankill says:
Idk how to read it xD I don't get how to read the minutes?
May 20, 2009. 12:05 PMstephenniall says:
Oo cool but im gonna do this with a old bicycle cog
May 20, 2009. 11:12 AMjudith_ou says:
Wow, I love this project: it's so simple yet I never would've thought of it. Looking forward to giving it a try!
May 20, 2009. 4:41 AMwgrazier says:
What a cool post. My brain is buzzing with ideas of turning my boring wall clock into something cool, too. Thanks for sharing.
May 19, 2009. 10:04 PMChrysN says:
Great work, turning a plain and ordinary clock into something funky and unique, and getting it done in the course of watching a movie. Nicely done!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
90
Author:Doctor What
