3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Soda Bottle Water Rocket
Step 3Bottle Merge
Bottle Merge
Take the cut bottle from the previous step and insert it directly over the bottom of the other bottle - this becomes the nose cone of the rocket. Try your best to keep everything straight. If you put the nose on crooked, your rocket will fly crooked. Place the nose cone on loosely at first, then gently press down until firm. Turn bottle upside down and let it drop on a hard surface several times. If you press the nose cone on too hard, you'll start to get "crinkles" in the plastic. Crinkles are bad.
3 comments
May 7, 2010. 3:33 PMSchober says:
There is a way to splice the two bottles together so that you get an increased pressure chamber instead of having the other bottle being just dead weight on your rocket. Be advised this does take much more time and is far more costly than simply attaching the other bottle, but it seems to me like it would be worth it. I did not make this video I'm simply sharing it with the people.
Aug 10, 2010. 11:30 PMpaperclip32 says:
I think getting all the materials to do that would cost too much.This is just for kids,anyway.
Apr 20, 2011. 7:54 AMepic sonic says:
ever thing is cheap except for the foam core
but you can buy it at the $Rama for $2.00 but then its not as good as if you buy it at
staples
thanks for your time
Apr 21, 2011. 8:11 AMpaperclip32 says:
I was referring to the video Schober posted.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:cyenobite
