3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Soda Can Fireplace !!!
Ok so this is my first instructable. This is a fireplace made out of a soda can.!!!!!
Step 1Make Slit in middle
Make Slit in middle
Determine where the middle is on the can (see pic) and make a slit thats about 1 1/2 inches long (see pic)
68 comments
1-40 of 68next »
Jun 6, 2011. 3:18 PMamelder says:
Dude, you failed to mention how fast this thing can heat up. I just burned my fingers. I know it has fire in it but i thought i would have a second or two to close the door. but nope burned me the second after i lit it.
Sep 8, 2010. 5:35 PMLexiLovesPie says:
I made a heater from two soda cans so basically just take the bottom inch off both the cans make holes in one part put fuel in the bottom part and interlock them
Feb 28, 2009. 10:21 AMbylerfamily says:
WOW!This is great!When I tested mine it gave off a lot of heat.THANKS!
Apr 26, 2010. 4:10 AMahmad5204 says:
 Thanks Man I be going for a picnic with my grandad he's gonna be impressed
Apr 21, 2009. 4:11 PMcrayzclown1 says:
perfect for smores, use rubbing alchahol for indoor marshmallo making
Sep 18, 2009. 6:19 PMtigerboy says:
you shouldnt burn any thing indoors including rubbing alcohol
Jun 4, 2009. 9:11 AMstephenniall says:
Great idea have just made one as a heater mine didnt work as wel as i wanted it to so i added some air holes (pin sized) that i could turn off etc with pins and put some sticks in it some ordinary toilet roll with some Methalated spirits (white spirit) in lit that and closed it Its still crackilin now ! rated 4.5/5
May 31, 2009. 10:02 AMkaika says:
I really wish I could see a pic of this heater in action. I'm having a little hard time imagining how it should be used >.<; but looks like a great camp idea!
May 12, 2009. 4:15 PMStephon #9 says:
ya its good i flipped the can and boiled water with it! lol i used gas soaked sticks,kleenex,and a strobe to lite it
Apr 18, 2009. 4:17 PMEtch3 says:
You did great on your first instructible!
Feb 27, 2009. 3:44 PMbylerfamily says:
I love it! I am going to make one considering tomorrow is Saturday.
Aug 27, 2007. 9:43 PMZo1x says:
i made this, and surprisingly, it gave off alot of heat, but a bad smell, But probably because i used paper.
Feb 27, 2009. 3:42 PMbylerfamily says:
The bad smell was the protective coating on the aluminum foil.
Aug 22, 2007. 11:45 AMPCvsMac says:
Pretty Cool! Now you actually fire! Also, incase the starts to get hot, would it be an idea to wrap duct tape around it? (Except from the holes :))
Feb 27, 2009. 3:40 PMbylerfamily says:
If you wrapped duct tape around it the duct tape would start to melt and smell horrible.
Jan 11, 2009. 6:45 PMzafiros says:
I made this, that made a couple modifications. 1. I removed the door 'cause I felt it was unnecessary. 2.i cut the scraps horizontally and made a chimney by stuffing them in the top
Oct 11, 2008. 10:27 PMiglo1234 says:
i was gonna do this same thing and post it but i got burned WARNING:i made this a couple months ago and i lit it, it got so hot that it burned my hand and finger prints clean off THIS IS VERY DANGEROUS SHOULD ONLY BE USED for DECRATIVE PURPOSES ONLY
Dec 28, 2008. 7:21 AMThe Red Button says:
haha, if it gets hot thats good. just dont touch it
Dec 27, 2008. 3:48 PMThe Red Button says:
Yeah, i just made an instructable like this. And i saw this in the related section. Your door is way simpler but i think mine looks cooler.
http://www.instructables.com/id/SodaCan_quotstovequot/
Dec 5, 2008. 2:35 PMebayebay1 says:
cool u should add a pic of it on fire
Oct 26, 2008. 12:46 PMcorey_caffeine says:
i just accidentally a whole mini fireplace!! is this bad?
Nov 26, 2008. 6:37 PMFather Christmas says:
wait, i think i missed something here...
Sep 29, 2008. 4:30 PMJesusfreak101 says:
Does the door serve a purpose other than decoration?
Sep 15, 2008. 2:02 PMBEAST14 says:
could you put quick dry cement in the bottom insted of sand?
Jun 9, 2008. 9:15 AMmattccc says:
can you cook stuff on it
Jun 8, 2008. 2:08 PMbigfootduck says:
Nice! A little outdoor heater! I can use this for campouts! Thanks for the instructable
Apr 27, 2008. 5:06 AMloggerhead says:
pretty cool:)
Apr 10, 2008. 5:04 PMdidough says:
Brilliant, always assuming you are in the woods with a can, scissors, hole punch, sand, paper and matches of course!
Jan 20, 2008. 3:03 PMDomindude3 says:
That would be useful if you were in the woods I guess, but not so if you don't like hot tin cans. It is also easy to make. God job
Aug 31, 2007. 8:52 AMBrowncoat says:
I'm confused about the "make handle" step. You say it's so you can open the door, but you show the door already open before you get to that step. So why do you make the handle...? (Asking, not being rude.) Do you leave the door open or close it when burning your stuff?
Dec 12, 2007. 2:51 AMDrCoolSanta says:
You sure you made it? [/SARCASM] Considering that opening it would be difficult if the door would be closed, but with that cut you can poke in your finger and pull the door. You get to see this in some bottles, but in that case it is a dent.
Sep 29, 2007. 1:42 PMBardouv says:
I decided to do this, but i figured i'd mod it, so i added some leather to the outside so i could pick it up. It worked okay until i burned a bunch of notes. I guess to much heat got kept in because of the leather and the can melted. Then the leather caught on fire and i had to put it out. *tears*
Sep 23, 2007. 7:27 PMthreecheersfornick says:
Ok, I really like this, but I'm a little confused about why we're making a hole in the top... is it just to make a chimney?
1-40 of 68next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:judelizowski
i like Making instructables and reading. i hate school. My fav band is gorillaz. My fav show is Friends....
