Soda Tab Chain Maille Inlay
Introduction: Soda Tab Chain Maille Inlay
There are several instructibles that show methods of how to make "chain maille" from soda tabs, so I don't want to reinvent that wheel.  Having been a professional costumer, I have had need to make some lightweight "maille" that looks better than spray painted burlap (an industry standard).  My kids love their shirts...  After all, how many kids have their own shirt of chain maille?  But there was a problem... how to tell them easily apart from each other?  It's not like kids need to fight over whose shirt is whose...  I have come upon a rather nifty way to make a soda tab maille shirt a little more individual...  with inlays!
Step 1: Get a Pantload of Soda Tabs
I seriously recommend that you get a PILE of tabs before starting such a project.  It's not really too hard to accumulate a large number in a short time... ask everyone you know to save them for you.  You'd be suprised how many come your way.  I have a brother-in-law who saves them, and brings them to me when he comes to visit!
The other part is to get more than you need.  Really.  It always takes more tabs than you think, and nothing is more frustrating than trying to finish a piece when yiou have run out of tabs!  You might find yourself wandering the streets, looking for the errant aluminium can, hoping... hoping...
Step 2: Get Coloured Tabs
The coloured tabs are the important part.  After all, you can't tell the difference otherwise!
More and more beverages are going to a coloured tab, particularly energy drinks.  A large portion of mine come from Rockstar and Redbull cans.  But be careful with these tabs as well...  Usually one of the two "windows" in the tab is unpunched, leaving it for you to CAREFULLY remove the "pane" with snips or other metal removal tools of your choice before use in your inlay.  This is sometimes the only way you can get a particular colour into the weave.
Step 3: Lay Out Your Image on Paper
For those who like to do things by "the seat of the pants" method, you can skip this step, though it does save a LOT of time in the end.
Find the image you wish to inlay.  The more simple, the better. This is not to say that you can't use a cool pic that you found somewhere, it just means that it needs to be made more "simple"...  Think about how a pixellated image gets the idea across without all of the detail.  That is what you are wanting to go for for inlay on a piece that will be used as a costume.  Much larger pieces can be done with lots more detail, but for the scope of this exercise, we are doing the minimal detail.  Hence a cross in my demonstrated inlay.  It could only be simpler if I did a straight line.
Make (or purchase) a piece of graph paper with a 1" grid.You can also find graphing paper online that can be printed to any size.  I would recommend the paper be no smaller than 12X12" (if possible).  I've taped multiple pieces together (lining up the grid) to make it as large as I need.  Then "fill" the grid in with your design. Each square represents a single tab.  So filling in the squares with your design colors, this gives you a good idea of what it will look like once assembled. This is much like making a cross stitch pattern, though a great deal larger.   This lets you know what colours go where.
Instead of actually colouring in the squares (which is just fine if you like), I like to just place the actual tabs that I am going to use on the paper.  Then, as I construct it, I can just remove each tab from the paper as it goes into the final piece.  If you are going to make more than one piece with this particular motif, I would recommend doing the coloured in squares on the grid, so you can accurately make the image more than once.
Step 4: Make a "starter" Piece of Soda Tab Maille, Then Add On
The starter piece is to help accurately place your coloured tabs in the finished piece.  It should be at least as many tabs wide as your inlay tabs are going to be.  So if your inlay is 12 tabs wide, make the starter piece 12 tabs wide.  4 or 5 tabs high is enough to make sure you have the weave in place as it should be while adding the coloured tabs.  No, it won't explode if you misplace a coloured tab..  But it can be a pain if you put a tab in the wrong place!
It is easiest if you add the inlay tabs one row at a time.  That way, you will be able to keep it all straight.  And should you need to put it down and come back to it later, you will know right where you left off, and where to start up again (Which will minimise swearing and aggravation).
Depending on your method of constructing the soda tab maille, you may have some distortion in your image when it is used in the final piece.  But hey, that's what experimentation is for, right?
Step 5: VICTORY!!!
Though it  looks super nifty, this "armour" will not protect you in ANY WAY from sharp implements.  Please bear this in mind.  It is for decorative/costume use ONLY.  Really.  If you decide to use this for any sort of armouring purposes, I will not be responsible for your stupidity.  Just sayin'.
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    I take it the "I drank it all myself " price is $150 IN BEER tabs and another $75 in jump rings.LOL What size jump rings did you use.....and /or did you make your own?
    I would guess it would be right around $150... That sounds about right... I make my own jump rings, these are 14 ga. galvanized steel wire with a 3/8" inside diameter.
    Are there pictures missing from this instructable? It appears that the method of combining the soda tabs is missing, where words would not suffice. More pictures with details would be helpful in making this a more constructive instructable.
    Wow! He looks great in the costume! I wished I had the patience to make one! Thanks for sharing your hard work and please remember to have a splendorous day!
