Introduction: Soft Latching Power Switch ON / OFF Circuit
Picture of Soft Latching Power Switch ON / OFF Circuit
Simplest Soft Latching Power Push Switch ON/OFF Circuit
This soft Latching Power Switch circuit design contain only two transistor, resistors and momentary push button switches,so this is one of the cheapest way to get your work done
You can use any Transistor in this circuit, just it will need to find proper ressistance value accordingly, cheap don't always worst this circuit only consumes 1.8 Micro Amperes at off state
You can really improve this circuit by replacing mosfet's instead of transistors
Step 1: You Will Need
Picture of You Will Need
1. 1 kilo ohm ressistors *2
2. bc547 and bc557
3. Two push buttons
4. Protoboard
Step 2: Circuit Diagram
Picture of Circuit Diagram
Follow this circuit Diagram
Step 3: Watch Full Tutorial
Picture of Watch Full Tutorial
HamidM38 (author)2017-12-19
merci
HamidM38 (author)2017-12-18
Merci pour votre aide
SandeepT23 (author)2017-07-06
Im a very beginner to electronics.. Just a simple question.. What will happen if you hold the button for few seconds when the LED is off (or in on state also).. Will it toggles the state quickly?? If so how can we avoid that even if we holds the line for few seconds..
TecDroiD (author)2017-04-24
nice work. would this work for 36v, too or would i need other transistors?
btw. when i want to use a microcontroller to switch this thing off, i suppose, i should use a third transistor to switch the npn base to ground? (especially when using 36V)..
Doc Darkness (author)2017-03-19
well explained and well executed thank you for posting
Fearce1 (author)2015-11-27
I think the circuit sim was
http://www.falstad.com/circuit/
Here is a single button circuit I found
LukaM5 (author)Fearce12017-03-11
no, it was everycircuit http://everycircuit.com/app/ the free version has a limit of 5 components though, to it's pretty useless.
mirws (author)2017-02-05
How to use it on 3v3 system?
josephchrzempiec (author)2015-12-06
Helloin your specs you have the 2 transistors and 2 of the 1k resistors But in your Circuit Diagram It haves all that and a 100ohms resistor. What is that for?
neumanngregor (author)2015-09-10
Frend, what program do you use for the circuit simulation, its amazing ?
Volthaus Electronics Laboratory made it! (author)2015-06-30
This is a very fascinating circuit. I have tried some slightly different configurations of your circuit and I am able to turn on and off a circuit using only one button on the Infrared remote controller. I was also wondering what were the second pair of transistors you tried in your circuit in the video? I could not catch exactly what you were saying. Also of use is the impedance change on the output of your circuit in my variation. Now to see how using mosfets work. Thank you for posting this, it is very fun!
henkoschoeman (author)2015-06-26
how wil you build circuit using only 1 button
BeachsideHank (author)2015-06-21
You have fully documented your build, and shown the theory of operation in a clear, understandable and intelligent manner, as well as demonstrating possible alternative uses; this is the way of a good educator, well done!
Thank you sir.
DIY Hacks and How Tos (author)2015-06-21
Nice circuit design.
About This Instructable
20,645views
50favorites
License:
Bio: Ideas Into Reality !
More by Kedar Nimbalkar:Make Night Vision Camera From Old Smartphone !Fidget Spinner that spins itself !DIY Wireless Charging for Your Gaming Mouse ! - Goodbye Batteries
Add instructable to:
