3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Softmod Your Xbox (play games without disk) **UPDATED**
Step 3Using Xbox Live
Using the Xbox Live
If you desire to play online you'll need to make sure you never modify the files located in 'E:\Backup\' or 'E:\Backup\Modded\' if you do then the included scripts won't work correctly as the scripts expect the files it needs to be located in these directories.
To reset your Xbox to the Microsoft Dashboard simply choose 'Waffle Zone Tools' press 'A' to enter this menu and now select 'Backup Menu' and press 'A' the next item to select is 'Restore Unmodded Backup' press 'A', the script will start copying the needed files, after it is done reboot and play the Games you want online (of course you need the Original game).
A possibility exists that Microsoft will eventually implement a check for these type of exploits and when discovered will Ban your Xbox from be able to use the 'Live' service.
When you want to revert back to the Softmod you basically repeat the steps to do the exploit the first time with the exception that you should choose 'WaffleTools' then 'Backup Menu' (NOT Install UXE Package) now here simply choose the option 'Restore Modded Backup' this will copy the files needed to revert your box to the UnleashX dash, once complete reboot your Xbox and you should be back to the UnleashX dashboard.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:surffinn
