Soil Moisture Sensor - Intel Galileo
948
7
Posted
Introduction: Soil Moisture Sensor - Intel Galileo
This is just a simple tutorial to guide hardware enthusiasts on how to set up a soil moisture sensor using Intel Galileo. Just follow the steps below to get started
Step 1: Brief Description
Essentially a Soil Moisture sensor measures the water content in soil, whereby, without much of a stretch you can tell when the soil needs more water or when it's over-watered. At the point when the dirt dampness decreases, the sensor output will decrease in value.
The two probes in the sensor are used to pass current through the soil, which will eventually read the resistance to get the moisture level. More moisture allows soil to conduct electricity easily due to less resistance, while drier soil does not conduct electricity well because of higher resistance. This will enable you to judge when and whether a plant needs water or not, simply by observing the sensor outputs. Finally, my hope is that after reading this excerpt you will be able to make your own soil moisture sensor using the Intel Galileo to keep track of the water to improve the plant growth in your garden :-)
Step 2: Acquire Hardware
The Soil Moisture sensors can be acquired by purchasing it from eBay, Amazon or any online electronics shop. It is affordable to anyone who is serious with the project
Step 3: Requirements
Components
Intel Galileo Board
Moisture sensor module
Breadboard
Tools
Side cutter
Stripping knife
Multimeter
Materials
Power Cables
Power supply
Jumpers
Pin definition:
Analog outputs
Digital outputs
Black wires
Red wires
Software
Text Editor – (Sublime Text for my case)
Step 4: Backend
The back-end code is built in C++ using sublime text interface. This can easily be done using sublime text, one of the most popular text editors
Step 5: Build Environment
The type of board used to test is the Intel Galileo Gen 2, but any type can be used. Following the code, sensor data is received by A0 pin, you can use any as well
The test data was showing values above 300 when the soil is moist and above 500 when dry. When placed in water the value dropped to 100.
Your values might vary from the one I used to run the test depending on the environment that you are. But that does not mean you are wrong. Testing it in different environments will show you how the sensor output values changes with the different soil moistures. This shows you how essential the Soil Moisture sensor using Intel Galileo can be.
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    2 Comments
    explanation well put. Thanks
    Great idea! Thanks for sharing.
