3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
SoilMaster 18,000 (prototype)
  • last photo ←
I've been wanting to build myself a composter for quite a while now. A few months ago some family of friends gave me a bunch of these 15 gallon plastic jugs, so I set about a plan to put them to use. Due to the limited volume (I certainly would have preferred 55 gallon drums), I decided it would be best to incorporate several of them into the contraption to increase output while maintaining roughly the same footprint (maybe something like 2/3s what it would have been if I'd built 3 separate units, anyway). Also, I thought this would be more fun.
Oh, so, a description...
It's a three armed composter. Each arm incorporates an independent composting unit. These arms/units may rotate as a whole as well. The idea being that when one is full it can be shifted back and allowed to cook while the next one is brought forward and gradually filled.
16 comments
Sep 26, 2010. 1:33 PMr9x says:
Can you make a PDF version of this?
Sep 22, 2009. 9:52 AMunbentcrayfish says:
OH MY GOD!!!!!!!!!!!!! XD three of them!!?!??!? damned man..
Nov 12, 2008. 5:40 AMArtaxerxes says:
your composter is really cool. I don't know how much work you've done with those containers in the past. I'm guilty of a considerable amount of home garden ingenuity involving plastic barrels just such as those. They are great to work with as they are clean, and easy to fabricate into something new. The down side: They do not hold up to UV exposure worth a darn. They become extremely brittle and fragile after about 1-1.5 years in the sun. However, I'm guessing you need to cover or paint your barrels with something dark in order to get the high composting temps. If that coating/covering was something that would substantially block UV it might dramatically improve the longevity of your creation. I'm interested to know how it works out.
Jun 19, 2009. 5:22 AMEagleScout316 says:
Maybe a Black Shimmer spray paint with an Epoxy base?
Nov 23, 2008. 2:31 AMrobert g says:
I enjoyed your take on the composter, thanks for the inspiration, you got me thinking. when we lived in the city we had a small yard, I tried to have a garden, but did not have a green thumb. We did learn some thing, composting, that is we took our organic materials from the house, the grass clippings, the neighbors leaves (when in season) and composed them. To blend and mix all the materials evenly I put my weed whacker in a garbage pail then dropped in all the organic material we collected from the week and weed whacked the material into a uniformed blend. This seamed to speed up composting. To this day if I want to reduce the amount of leaf bags I use I'll still drop my weed whacker into the pail and reduce the leaves, now they are easier to compact in the bag.
Nov 22, 2008. 8:08 AMbenin says:
great
Nov 12, 2008. 4:43 PMmrdiablo9 says:
Exellent, I like the concept and the ergonomics of this, how long to put this baby together? Has this sped up the decomp in any way? Either way the minimizing of bending over to turn the compost is great.
Oct 28, 2008. 8:48 PMfuzvulf says:
Love it, Have a suggestion, a round piece of wood attached to one end of each barrel with a belt that goes to the center and rotates the outer drums as the outside is turned. Some of the high end composters incorporate a crank that you turn to turn over your compost and speed composting. But, great, love it, looks like it would be the ideal height to just park a wheel barrow under one of the drums, dump your compost and take it to the garden.
Oct 16, 2008. 4:39 PMPKTraceur says:
3 words......... Unbeleibly Insanely awesome!
Oct 16, 2008. 4:18 PMlucek says:
I use a 25 dollar one from my citty and a trash can.
Oct 14, 2008. 10:54 AMshooby says:
This is pretty damn cool. Although you mentioned footprint minimization, I assume you have a reasonable amount of outdoor space. Maybe a future version of this could use piles (posts) fixed into the ground, instead of the larger triangular base you've built for this one. Any reason for the height?
Oct 13, 2008. 12:37 PMcanida says:
Looks good! I'd love to see the full build of your next version.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:jellysix
